I looked into water transfer decals and it was just over $400. If you still have your original body panels you can get almost any pattern/color you want.
It was a shop in Michigan that specialized in that process. They started out doing guns and as the business grew they are able to handle larger sized parts. That price was based on getting the hood and fenders done. You need to remove and install panels yourself, they prep and dip. They basically print a decal, float it in a bath, then dip the part into the bath to transfer the decal to the part. You should be able to find a local shop that can do it. When I looked into it the price was less that buying new Honda panels. You could get most any camo pattern or graphic design.
