P1000 Repurposed front bumper
LaVell
LaVell
181
369
Opp, Alabama
Instead of buying a rear bumper I decided to turn my old stock front bumper into a rear. Cheap fix. Had a couple of extra draw bars laying around, so i put them to use. Nothing fancy just pull the pin and remove if you need to use the dump bed.
82D3DB6A 1A84 4C58 8439 2E7FF6C6C6DD E3422F85 B61C 4FE0 8C44 33BE3A8B4FAB 90FE21AA 4502 4BC2 8138 06BFD7DA822B 743A8341 F0EF 4F45 92CB 8AB28974D5A3
TripleB
TripleB
15,241
136,128
Caryville, Tennessee
Reactions: BWAF
ToddACimer
ToddACimer
Pioneer 1005-2
3,673
15,526
Oshkosh, Wi
Is that mounted to the hitch?
Reactions: BWAF
208,726
BWAF
BWAF
I get paid to pass gas
8,863
42,472
Carthage MO
sek-hunter
sek-hunter
317
617
Well I’ll be damned.
That’s awesome. Where do the two bars go that are on either side of the bat that goes into the receiver?
LaVell
LaVell
181
369
Opp, Alabama
I cut a 1inch piece of square tubing to go between the two bars. I welded it to the top draw bar and the two braces to help stiffen it up and not twist.
Reactions: sek-hunter
ehart814
ehart814
1,653
3,631
NWPA
That looks great. Would do a much better job of protecting down low (muffler, suspension) than one of those simple tube bumpers that doesn't look like it would do much of anything. I got rear-ended hard when I had my 500 and it actually bent the muffler. Your bumper setup would prevent that
