K
I have searched and can’t seem to find my answer. I am wiring a reverse camera that the screen shows a constant view of four camera angles. However I am attempting to wire a trigger wire for reverse when the bike is in reverse it only shows the rear camera view. I ran my trigger wire and attached to the Hondasxs pigtail for the reverse circuit and the camera switches to the rear camera angle when in park. I tried swapping the trigger wire to the ground wire of the same pigtail and still shows the rear camera angle when in park. I metered the pigtail and am getting voltage on both positive and negative enough for it to trigger the reverse camera while in park or drive. What am I doing wrong? Has anyone run into this issue what did you do to fix it. Any diagrams would be greatly appreciated.
