P500 Reverse light wiring
hondabob64
hondabob64
215
795
Louisiana
0354CC29 B03C 465C A547 1AB18F27D7E0
I’ve bought a Honda OEM sub harness to power two rear mounted led cubes as back up lights. It plugs in under the hood & I believe the yellow or blue wire is the trigger wire for the back up alarm (which I’ll be using for power). Any one else try this?
JCart
JCart
895
2,020
Kamloops, BC Canada.
I use a VisionX small LED back up light, very bright, in center of cab rear facing. As I have auxiliary battery underhood I wired to that with a relay and switch inside cab lower center of dash.
Mine has a white beam.
LED-Utility-Flood-Light
66,818
I believe @Hondasxs is currently working on a "plug N play" reverse light for the P500.....
I will have the plug-n-play reverse triggers ready early next week.
This ONLY gives you a ground trigger point.
Hook it to the light and + to the light and it comes on when in R.
You can also use it to trigger a relay. The relay will then be your + switch.
Lilred500
Lilred500
Keep it on the rubber side
548
1,997
Wv
Is the trigger switch available now?
K
KevinAxe
5
AR
Does anyone know how much current the reverse trigger will sink? Will a relay be needed with an LED light that pulls 0.75 amps?
Thanks,
Kevin
66,818
Thanks,
Kevin
Did you already install the backup light trigger kit?
Cant speek for the factory backup alarm kit. But the one I designed for the he 500 can handle a few amps.
Thanks.
Reactions: Mudder and Mudwing
K
KevinAxe
5
AR
Just got the backup alarm harness from Honda but haven't installed it yet. Guess I'll play it safe and put in a relay. Thanks.
