Reverse on the Pioneer 500!
64,750
Anyone read how the reverse works on the P5? I see there is a lever you have to pull. Only seen a slight picture of it. Nothing up close.
I assume it will then allow you to down shift. Kinda like the Red (R) button on the manual Honda ATV's.
Anyone confirm or have more info on this?
42,240
Saw it somewhere...
You go down to 1st or neutral, pull the lever, and then downshift...if i recall properly.
chancesemar89
chancesemar89
132
78
louisiana
Yes I read about it. Just like that atvs just with this one pull the lever in the lower middle of the dash and down shift .
64,750
So, I that makes the reverse gear part of the main transmission and not a sub transmission.
It would have to be part of the main.
I guess it could have a gear that meshes with a sub trans only when you downshift from first with the lever in the correct position. Like the PTO on some truck trans, It could go out the side, but I don't see how it would then control the drive shafts.
Prob same setup at the 500 class ATV it's borrowed from, why try something new when you can use something that you know works and change a bit of linkage.
truckracer
11
0
Using the left paddle (down-shifter), shift down to neutral, pull the lever in the center of the dash, shift down once more.
64,750
Compared to the forward gearing. What gear could you compare reverse to?
Hopefully second or third as first would be way tooooo slow.
Thanks.
truckracer
11
0
Reverse is similar to second.
michaelbach
48
7
I would say its close to 1st gear
truckracer
11
0
Ok,
Here are the gear ratios for the 500 Pioneer.
Low 4.230
2nd 2.388
3rd 1.608
4th 1.178
5th 0.848 (overdrive !)
Reverse 5.743
4.077 both front & rear differentials
So reverse is lower than even the ultra low 1st gear - That was not my driving impression, I will have to experiment with that more today.
64,750
Woohh. That's going to be a creep.
Let us know what find in real life.
Looking for reverse top speed and does it gear out or rev out.
Thanks.
truckracer
11
0
Thanks.
Ok, we tried this a couple times with a GPS - both times 5.9mph and its definitely on the rev limiter.
