P1000 Rim and tire size on all 4 corners. Final answers needed.
Rangejunkie
Rangejunkie
44
108
Jackson, MS
Ok guys. This is something that I am hoping to do to my bike. A pioneer 1000-5. I have seen the question asked a few times but with answers all over the place reguarding offset, rim size, tire size, spacers needed or not. Weather a lift is installed or not used. So I think it would be a good idea to compile a list of what works. Possible sticky if @Hondasxs wants it to be.
I would like for the following info to be listed on your setup:
Lift? Y/N (if so what kind / size)
Stock/ Forward/ aftermarket A-Arm?
Shocks used (if aftermarket what settings)
Rim size (deminsions with offset used on all 4)
Tire size?
Spacers used ( what size/brand): Y/N
In the end is it close to stock width, or did you gain alot of width?
Hopefully this will answer some questions I and others have pretty clearly on how to get their bike set up and what all is needed to do so.
Thank you to everyone who puts in their info.
Lift? Y/N (if so what kind / size) Yes, 2.5 HL lift.. Have to run the lift with my tires for clearance.
Stock/ Forward/ aftermarket A-Arm? Super ATV arched forward and rear offset arms
Shocks used (if aftermarket what settings) Fox QS3.. 2” of preload up front, 1” on the rear (measured by silver showing from spring retainer nut)
Rim size (deminsions with offset used on all 4) sti beadlock 14x7 4/137 - (5+22) [14HB127]
Tire size? 30” berserkers (very true to size 29.5” on the machine) @8psi
Spacers used ( what size/brand): Y/N... Yes, front rb3 1.5”... rear 2” SATV
In the end is it close to stock width, or did you gain alot of width? I’m around 69” wide
33E8C33C 8784 48EF 98F0 452913F00C85
Rangejunkie
Rangejunkie
44
108
Jackson, MS
Thank you @JTW maybe some others will post to give more selection on setups.
Reactions: sharp and JTW
Rangejunkie
Rangejunkie
44
108
Jackson, MS
Does anyone else have any input @JTW know anyone else?
Reactions: sharp
Neohio
Neohio
Beast of the East
21,761
93,350
Painesville Ohio
Lift? Y/N (if so what kind / size) Highlifter Bracket lift
Stock/ Forward/ aftermarket A-Arm? Stock
Shocks used (if aftermarket what settings) Stock deluxe
Rim size (deminsions with offset used on all 4) 14x7 4+3
Tire size? 28x10r14
Spacers used ( what size/brand): Y/N, spacers on rear. 1.5"
In the end is it close to stock width, or did you gain alot of width? lots of width, total width not measured.
Reactions: Landman
clifforeilly
clifforeilly
WFOSXS.com
795
2,688
Goodhue MN
Lift? NO
Stock/ Forward/ aftermarket A-Arm? STOCK
Shocks used (if aftermarket what settings) STOCK base model
Rim size (dimensions with offset used on all 4) RACELINE TWIST ATV 14 X 7 4-136.00 5+2 BKMTMS all around (can 4 tire rotate )
Tire size? BFG KM3 Mud Terrain 28X10.00R14
Spacers used ( what size/brand): REAR ONLY 1” Super ATV (AMAZON)
In the end is it close to stock width, or did you gain alot of width? Maybe an inch wider.
Wheels and tires bought from Discount Tire. They will beat any price .
Loving these tires ! Very quiet !
Bfgs
Side
Front view
