P1000 roadlife 52 inch led light bar..
Craig1982
12
56
Illinois
  1. Looking to buy
  2. 1000-3
need a little help. i have a roadlife 52 inch led light bar. i have installed a dual battery system with position and negative bus bars.
This light bar I have has a 30 amp fuse. Can I run that through the fuse box or does it need to go directly to the battery?
Reactions: TxDoc
NTCPrezJB
NTCPrezJB
Retiring Member
112,670
974,972
Hidden
Technically it would work either way. You certainly don’t need two fuses on the line but that’s kinda like saying you don’t need 36” of wire for a 24” wire run. Sure it adds a little bit more resistance in the circuit but it would still work.
Reactions: TxDoc
TxDoc
TxDoc
2,431
7,831
TEXAS 🇨🇱
photos.app.goo.gl
You can trigger it to come on with a relay. A relay is a "switch within a switch." When triggered it allows power from the battery to the light and protects a switch not rated for that many amps.
They may not help, if I misunderstood the context.
Sent from my motorola edge plus 2023 using Tapatalk
