P1000 Roof , doors, rear window to accomadate SATV windshield
K
Kelldog
55
120
I dont really like the SATV roof and doors. Who else can fit with the SATV flip up windshield
Reactions: Lady01
Robobrainiac
Robobrainiac
2,551
8,963
I have the SuperATV flip up windshield with Honda OE roof and OE soft doors and it works great. There are many people on here who have many of a mixture of things that all seem to work with each other.
sek-hunter
sek-hunter
317
617
Same here, gen 2 upper Honda doors and hard Honda roof....
Reactions: Lady01
K
Kelldog
55
120
Is the OE roof with the satv windshield leaking bad during rain? Seems to be some complaints about it
Reactions: Lady01
c_carrierlj
c_carrierlj
34
105
Ellsworth, Wisconsin
Literally rode in rain yesterday afternoon with that combo, and not one drop leaked in. Wasnt pouring rain but still....
Reactions: Lady01
sek-hunter
sek-hunter
317
617
There is a thread somewhere that offers a template to a piece that can be cut from clear vinyl material (like jeep windows) that attaches to the top of the windshield and roof. Allows the window to open and close as intended and blocks 100% of the wind and rain from the gap between the windshield and roof. I couldn't find another solution that allowed the wind shield to open and close as intended. Not sure who posted and created the fix, but it works flawlessly.
K
Kelldog
55
120
What are you using for the rear
JFID
9
11
NORTH IDAHO
I also have the SuperATV flip windshield with the OE roof and they work perfectly together!
How is everyone using the SATV flip up windshield with OEM roof it states it’s not compatible as the clamps for the windshield land right on where the roof clamps are. Did you use some kind of mod?
Robobrainiac
Robobrainiac
2,551
8,963
16-21 The OE Honda roof works with the SuperATV flip up windshield. I am not sure who says it does not. There is no modification needed.
JFID
9
11
NORTH IDAHO
What year is yours? I have a 2022 deluxe and had the roof installed at the dealer. I ordered the SATV flip up windshield and the top bracket that attaches to the bar lands right where the roof bracket is. It also states on SATV’s website not compatible but I’m hoping I can make it work because it’s $160 to ship it back to them.
Reactions: ODAMO
SuperATV
SuperATV
1,365
9,544
Madison, IN
www.superatv.com
I'm pretty sure you can make it work. I've had a few people struggle with it, but I've also had a ton of dudes say that it bolts right up with a little adjustment. You just need to loosen up the front brackets of the roof...and maybe the rear for more adjustment...and try to fit them together. Its tight, but they should work together.
They didn't really change anything on that roof, so I'm guessing the cage or jig for the frame has changed just enough to make it pretty tight.
Officially we're saying on the website that it doesn't fit, but its just going to need some persuasion if you have one of those machines that's just a little too close.
JFID
9
11
NORTH IDAHO
Great thanks I’m going to work on it
TripleB
TripleB
15,278
136,617
Caryville, Tennessee
Sometimes the front brackets on the roof are put on incorrectly. Which causes it not to work with the superatv windshield. I install the brackets wrong myself and had to swap them. That was 4 years ago and I cant remember any specifics. I've seen where other people have had the same issue.
JFID
9
11
NORTH IDAHO
Went on with no issues just needed to unlatch the front and middle roof clamps to give it a gap to get the windshield in. Just a little fiddling to get it 👌🏽- Fits perfectly. Thanks everyone!
0D65DBE8 3279 46EB A61B 2DA94122A42E
SuperATV
SuperATV
1,365
9,544
Madison, IN
www.superatv.com
SleepyFancyBat max 1mb
This....exactly. I've seen it a ton of times. Most were coming right from the dealer lot.
GovtMule
GovtMule
16,543
157,361
Tennessee
I was gonna say that. I put mine on last weekend. Had to take the roof brackets loose so I could get the SuperAtv brackets in the corners and then put them back. It’s tight but it fits. Need to knock it all down a little as the windshield just barely hits the lip of the roof when open. Pretty sure a BRFH will fix it.
  • Haha
Reactions: SuperATV
