P1000 Roof mounts for led pods?
Alaska350
Alaska350
96
233
Anchorage, AK
Has a anyone seen some kind of led pod mounts for the roof? I want run the high beam harness from the memeber store so I’m limited to the amount of power the lights can use. I can’t use the bottom of the window frame mounts because there is a big rubber boot there that is part of the hard door kit.
CA9F3830 2E9E 4BA6 BBE2 482CC735CB6F
208,726
Has a anyone seen some kind of led pod mounts for the roof? I want run the high beam harness from the memeber store so I’m limited to the amount of power the lights can use. I can’t use the bottom of the window frame mounts because there is a big rubber boot there that is part of the hard door kit.View attachment 323115
In my area, roof mounted anything is a no, no!
115,701
This black bolt right there. Can u get a more straight on pic instead of an angle Please? I may have a solution for you.
414D8B93 427A 413C BD38 7D499F7E8A39
115,701
Anyway, this is an old pick from long long ago in a Galaxy far far away lol of my rig. If you have access to those bolts, you can mount pods on those buy using a longer bolt. There are tons of pod manufactures that make pods in different sizes that will fit that area.
59E60D72 A624 45B3 87E1 6481F10395FD
Alaska350
Alaska350
96
233
Anchorage, AK
Thanks for the idea sir, i will have to investigate this option.
Reactions: Remington
66,868
Or consider using the high beam trigger to control a relay for a much bigger light.
Alaska350
Alaska350
96
233
Anchorage, AK
I bought this kit already which is why I am limited on the power consumption (72 watts). Bigger lights use too much power and I don’t have the bumper stinger or room on my bumper for the light bar recommended in the member store.
DC65E70E 42B0 454E 98C0 E32CDD15BA49
Reactions: Lady01
115,701
I bought this kit already which is why I am limited on the power consumption (72 watts). Bigger lights use too much power and I don’t have the bumper stinger or room on my bumper for the light bar recommended in the member store.View attachment 323178
You have the same bumper as I used to in the pic I posted. you have room to put some small cubes on the bars and a small light bar i the middle Just as shown in the pic.
those are cheep amazon LED’s that u can use. They worked great for me. there are better low profile less amp LED cubes now that u can in instead. Try Rough Country or Lifetime LED. there more money but worth it in the long run
Alaska350
Alaska350
96
233
Anchorage, AK
No sir, a middle led bar will not fit due to the front hitch plate i installed as shown in the pic. I bought the rough country black series led cube pods but need to get a bracket to install them on the bumper arms like you or install on the hood. prob will do the hood as I don't want them constantly being submerged in water when i cross creeks.
115,701
I don’t have a pic of it currently but if you invert your brackets on your bumper you can use that small white bar in the middle and it won’t interfere with your hitch plate. again, look at lifetime LED. They’re smaller put out a butt ton of light guaranteed for life and I’ve had mine submerged Many many times without issue. The pic I do have of this light is on my LE bumper in the middle
AD638FBD FFEF 4495 8BCE 7854A24016C6
Hillbillytnt
Hillbillytnt
550
2,023
Ky
That plug can be used with a relay to trigger whatever you want. It’s pretty versatile I have it run through an on off on switch and relay to power a 12” quad row on my bumper. I can run it with the high beams triggering it or just run it by itself.
115,701
I’m gonna dump the light bar by the way. It’s a pain in the ass and draws to much amps. Here’s a link to the clamps that I use.
Nilight 90020B 2 Pack Mounting Bracket Kit LED Off Road Light Horizontal Bar Tube Clamp Roof Roll Cage Holder, 2 Years Warranty https://www.amazon.com/dp/B0714CYKBJ/?tag=sxsweb24-20
Alaska350
Alaska350
96
233
Anchorage, AK
not sure what you mean by inverting the brackets. the hitch mount is bolted through the top and the bottom where the winch roller is so flipping it wont work.
Reactions: Lady01
Alaska350
Alaska350
96
233
Anchorage, AK
Those are actually the ones i bought but hated the look of them because they were slightly slanted......OCD man.
Robobrainiac
Robobrainiac
2,551
8,962
Where did you get the headlamp halos?
115,701
If i told you Id have to kill you! 😂 🥳
found them on Ebay 3 years ago when I was looking to update my std lights for deluxe LED’s havent seen them on there in a few years tho
