Robobrainiac
I installed the Rough Country Bed Extender. It fits well. I am a little disappointed in how thin the paint is. The instructions were very vague. Some of the descriptions and pictures were not totally accurate. In the parts list it shows button head bolts. In the pictures it shows button head bolts. They gave me hex bolts. I would have enjoyed button head bolts for aesthetics.
I had to cut a little of the interior of the bed to clear the bed extender side mounts. I had to slightly cut the bed liner as well.
The instructions want you to use the lower factory cable bolts for this step. I purchased a M8 bolt with nylon lock nut. I liked the fit better.
This is an example of the instructions. You can see in the lower photos the cable is installed on two different sides of the bed extender mount.
These little rubber grommets took me multiple attempts to find the best placement to reduce rattle. I also had to use washers to slightly space the grommets to get them to seat correctly to remove the noise the extender makes while driving. My grommets did not end up where the instructions illustrate.
I did not read or use steps 1-9 in the instructions. I am not sure how accurate they are. They instruct you on the removal of the tailgate. I had previously did the Tailgate Quick Removal Mod so I did not need instruction on removing the tailgate.
This is my Quick Tailgate Removal Mod
P1000m5 - Tailgate Quick Removal Mod
I am not sure if anyone else has done this. I wanted to be able to remove my tailgate quickly and easily. This is how I made that possible. This was performed on a 2020 Honda Pioneer 1000-5 Deluxe. It should apply to all 1000-5 and 1000-6 models. I assume it should work on the 700-4 since it...
hondasxs.com
