P500 Royal Purple Max Cycle
Idahocrawler
Idahocrawler
47
72
Is anyone running this? I’m going to do my first oil change and this stuff is readily available to me as the nearest Honda Dealer is 80 miles in either direction
Thanks
Reactions: rtn001
Idahocrawler
Idahocrawler
47
72
Thanks
Royal Purple® Max-Cycle® is specifically formulated to exceed the demands of highly stressed engines and transmissions. It is recommended for use in both air-cooled and liquid-cooled 4-cycle engines and is compatible with wet-clutch transmissions.
Formulated with select synthetic base oils and Royal Purple’s proprietary Synerlec® additive technology, Max-Cycle provides improved film strength when compared to the leading synthetic and mineral oil. Its shear stability and oxidation resistance promotes greater performance and protection.
Max-Cycle meets or exceeds API requirements and is rated JASO MA2, the highest wet clutch compatibility rating under the JASO T903:2011 Clutch Friction Test.
PERFORMANCE ADVANTAGES
  • Greater wear protection
  • Cleaner, more efficient engines
  • Superior rust / corrosion protection
  • Cooler operation and less parasitic power loss
43,589
I'm sure it's great oil.
I'm sure your local Walmart sells Mobil bike, Valvoline motorcycle synthetic, and even Supertech motorcycle synthetic, that's equally as great for maybe less money.
And I didn't even mention Rotella T6...
happyfred
happyfred
57
270
53
NY
If you change your oil regularly, they all are good..I change my oil in my machines every season.I use Mobil 1 10w-40 full synthetic Motorcycle oil. Walmart less than $10/qt.
Reactions: rtn001
HUCK
HUCK
1,047
2,319
ARIZONA
Mobil 1 synthetic 10-30 . $23.00 per 5 qt jug @ Walmart .
Reactions: rtn001
