After much research on upgrading to radial tires on my Can Am Commander, and because we can get full legal Arizona on road plates, run the highways, go to town etc. I went with Tensor Regulator tires, DOT approved 8 ply radial tires. Here in Arizona we have some nasty thorns & spines that can make small punctures, after several flat tires years ago people told me to use Green Slime, I have, and that has 'healed' those occasional punctures. But with the Tensor tires, designed as light truck tires for UTV's, they are so smooth & quiet running and tough I never have any concern with anything puncturing them, no need for Slime, run them dry, very tough, run straight & true at any speed. I've had my Commander up to 76 mph on the highway with the Tensor's and smooth as silk like a sports car, excellent at slow speeds also and plenty of grip. Imprinted on the sidewall they even list the correct PSI for different conditions... "Sand 8 PSI - Rock 10 PSI - Flats 15 PSI" For all around riding I keep mine at 12 PSI that is good for trails or pavement, but for a rocky trail I go down to 10 PSI. The two drawbacks IMO of being well worth it though, they are a bit heavy and the suspension not being quite as soft as with the stock 2.0 Bighorns that would puncture easy and wander above 30mph. Links, Tensor Tire...
Tensor Tire | High Performance ATV & UTV Tires At Rocky Mountain ATV...
Tensor Regulator Radial Tire | ATV | Rocky Mountain ATV/MC
Note; Must put the same size tires front & rear, I have 28" all around, took some time getting used to not seeing the rear tires larger and front tires smaller, but they look good & tough. Chicane makes a great tire also, researched both, I couldn't be happier with my Tensor tires though
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
On my Honda P-500 I have 25" Duro Frontier 6 ply radials, good tires but must use the Green Slime as thorns will puncture them. Hope this info helps.
P.S... Notice the front & rear amber turn signals on the Commander? what a huge project but worth it, now courteous & safe on roads with traffic.
View attachment 22129 View attachment 22130 View attachment 22131 View attachment 22132 View attachment 22133 View attachment 22134
