Crazy idea for a simple RV ac unit retrofit for a P1000 3 seater. It would require a small inverter generator that can be mounted on a removable "Pack out" base. This is how I would do it.
1. AC unit Dometic Penguin II High Efficiency Low Profile Rooftop Air Conditioner,
2. Pack out removable base mount to mount/remove generator.
3. Westinghouse iGen2500 Portable Inverter Generator
4. Go to a local Marine cavass guy and have them make you Strataglass removable windows
I would probably mount the generator beyond the tailgate facing the rear with some type of offset bracket.
The additional benefit would be the ability to overland with ac by ducting the ac to your tent as needed. The generator is removable so you can relocate it as well.
