P
Yes,can the same tire size be run front and back without causing any problem in 4wd?
thanks in advance...greg
Should be fine with 28s. The terrabites seem to be a well rounded tire for most conditions.Looking for single size tires as well. Located in AZ with hard pack, rocks and street legal. I’m looking at the Terrabites right now but looking for advise for single size. No plans for lift or any other suspension mods. My thought is 28x10x14, should I be concerned about rubbing going up to 28’s with no mods? Is there a better tire for my conditions? Thanks guys.
10 ply 27-11r-12 kanati mongrels the perfect tire on all 4 for everything except the roughest, toughest, and muddiest trails. no spacers no lift needed. absolutely no problem with the 11inch tire on the front 9inch rimLooking for single size tires as well. Located in AZ with hard pack, rocks and street legal. I’m looking at the Terrabites right now but looking for advise for single size. No plans for lift or any other suspension mods. My thought is 28x10x14, should I be concerned about rubbing going up to 28’s with no mods? Is there a better tire for my conditions? Thanks guys.
West Valley here as well. Right now I’m just researching. What tires are you running. I’ve only had the unit for a few months, so my list is long, not looking to get wheels right now. Also, not looking to add any height. Thanks.If you plan on running lots of black top I would look at truck tires. Mine work great for black top and desert riding. Oh and hello form the west valley. If you're near me you could try my spare to see if it will fit.
you don't need the big tires for Arizona, we run 1" wheel spacers all around and in the sand it moves and no probable with tipping or getting over the rock piles.West Valley here as well. Right now I’m just researching. What tires are you running. I’ve only had the unit for a few months, so my list is long, not looking to get wheels right now. Also, not looking to add any height. Thanks.
What size tires are you running?you don't need the big tires for Arizona, we run 1" wheel spacers all around and in the sand it moves and no probable with tipping or getting over the rock piles.
