P1000 same tire size front and rear
P
pgregory
19
19
lafayette tn
can the same tire size be run front and back without causing any problem in 4wd?
thanks in advance...greg
Reactions: Remington
Hondoman
Hondoman
727
1,695
Texas
Yes,
In fact most people do it to rotate tires front/rear plus being able to use a spare at either location.
105,443
That’s exactly what I’ve had since 16’. And yes, makes it easier for spare
Reactions: Hondoman
D_M_A71
D_M_A71
Arizona
Looking for single size tires as well. Located in AZ with hard pack, rocks and street legal. I’m looking at the Terrabites right now but looking for advise for single size. No plans for lift or any other suspension mods. My thought is 28x10x14, should I be concerned about rubbing going up to 28’s with no mods? Is there a better tire for my conditions? Thanks guys.
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,567
Greenville, Mo
Should be fine with 28s. The terrabites seem to be a well rounded tire for most conditions.
P
pgregory
19
19
lafayette tn
10 ply 27-11r-12 kanati mongrels the perfect tire on all 4 for everything except the roughest, toughest, and muddiest trails. no spacers no lift needed. absolutely no problem with the 11inch tire on the front 9inch rim
N
Nurm
24
79
Yooper
I have the 28x10 terrabites all around with red rims as follows. Tusk Terrabite Radial Tire 28x10-14 Medium/Hard Terrain4/137 STI HD7 Alloy Wheel 14x7 5.0 + 2.0 Matte Black/Radiant RedRide-On ATV/UTV Tire Balancer and Sealant with Mounting was $924 from Rocky Mountain ATV. I put 1 inch spacers on the back so the wheelbases matched. I do get a little rubbing if I turn to the stops, which i rarely do. Definitely a smoother ride and seem to be wearing well.
clifforeilly
clifforeilly
WFOSXS.com
795
2,688
Goodhue MN
Bfgs
DDDonkey
If you plan on running lots of black top I would look at truck tires. Mine work great for black top and desert riding. Oh and hello form the west valley. If you're near me you could try my spare to see if it will fit.
P
pgregory
19
19
lafayette tn
thanks guys...... went with 10 ply 27-11r-12 kanati mongrels the perfect tire on all 4 for everything except the roughest, toughest, and muddiest trails. no spacers no lift needed. absolutely no problem with the 11inch tire on the front 9inch rim
1900 miles on factorys....rear cudda gone at least 3k. 502 bux ready to roll!!!!!
Reactions: Cuoutdoors
russknight
russknight
1,916
7,542
Perry Florida
I'm running these.
https://amazon.com/gp/product/B017OF96G2/?tag=sxsweb24-20
https://amazon.com/gp/product/B07NGJRFBZ/?tag=sxsweb24-20
My buggy is street legal. I ride a lot on asphalt and dirt / limerock graded roads. Tires were balanced and don't shake at all. I paid 526.01 delivered to my door from Amazon.
Also running these spacers on rear.
https://amazon.com/gp/product/B07527CG52/?tag=sxsweb24-20
D_M_A71
D_M_A71
Arizona
West Valley here as well. Right now I’m just researching. What tires are you running. I’ve only had the unit for a few months, so my list is long, not looking to get wheels right now. Also, not looking to add any height. Thanks.
RB3offroad
RB3offroad
1,702
4,753
Tempe, AZ
you don't need the big tires for Arizona, we run 1" wheel spacers all around and in the sand it moves and no probable with tipping or getting over the rock piles.
D_M_A71
D_M_A71
Arizona
What size tires are you running?
