This has been a hot item...
I've heard good things about them. I also have one ready for my Talon but need to find time to install it.
Be sure to follow up with a difficulity level for installing and any tips or tricks.
I also have them in the club store available here -
HONDA TALON 1000 HEAVY-DUTY PROP SHAFT - RHINO DRIVELINE
But message me for an even better deal.
If ypu have a 2 post lift to use, it's an 1 hour job at most.
Remove middle skid plate(if stock) or remove skid plates that allow you to acces the front driveshaft loop and in front of the sub trans.
Remove the bumper/winch (if equipped with a winch)
Take all 2 forward front differential bolts out, loosen rear bolt but leave in, unclip the sensor wire on the drivers side
Remove the front driveshaft loop, I use a 12mm swivel socket (1/4" drive) and get it from underneath
We have a special set of inside opening pliers (Mac Tools) to get the clip open in the diff. Lube and brake clean help loosen it up.
Then use a pry bar to pry the driveshaft back while opening the clip
Remove the bolt from the differential and push it forward until the driveshaft comes out
Slide the driveshaft up into the cavity under the hood and drop it out the bottom (you may have to pry it off the sub trans, using the frame as a pushing point)
I can't find the plier part numbers, I'll look at them tomorrow at work
