This is my first post after enjoying reading through a lot of interesting posts and gathering information about my new 1000–5. I enjoy the unit but don’t like the fact that there are so many gaps for dust and later cold weather to get in. I am planning on sealing up the unit so that I can put my soft cab on. I have purchased enough weatherstripping, rubber sheeting, neoprene foam, and adhesive to seal a school bus. One thing I am tempted to do is to spray foam the hollow doors. I can’t stand the feel of the hollow plastic doors. They seem cheap and toylike. I am thinking about taking them off, drilling some holes in the top and bottom and filling it with great stuff expanding foam. I plan on removing them, removing the latches, and lightly clamping them horizontally with plywood. I also plan leaving the holes open so that expanded foam would be able to be released. I would then fill the holes with plastic pegs. I don’t think it would add much weight but would solidify the doors and make them warmer in the winter. Obviously my biggest fear is causing them to expand but I do have quite a bit of experience with the stuff and think it should work just fine. I will start with one door in the back so if it doesn’t work out it will be about a $50 mistake. Anyone have any ideas or experience with something similar or is my idea crazy?
