P1000 Second battery and stuff.
CaveMan76
Esko, Minnesota
Hey Everyone. I am new to the Pioneer world. I recently Purchased a 2016 P1k with a Boss V plow, heater and wiper installed. Now I have purchased the battery 2 kit but it really doesn't show where to connect the wires to. Also will that battery charge with the existing system or do I need to add a battery tender? From what I have read it looks like I should move everything to the second battery to reduce the load on the main is that correct? Ok one last thing the frontend seems to be way out of alignment (toe out) any easy ways to correct that.
Thanks for the help.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
For the battery there are kind of 2 ways to go.
1. Run accessories from secondary battery. Link both batteries together but have an isolator that keeps the power in the main battery from dropping too low.
2. Link batteries together with no isolater and make sure you dont leave things turned on. I went with this option and have never had an issue.
Setting the toe you can either use the string method or measure center to center of the tires. Measure front side and back side. Set toe within + - 1/8" of straight. Some like toe in some like it out.
Reactions: BigOL3
