P1000 Securing stuff under the hood
SlowPony46
45
68
IL
im putting a fuse block, ground bus, battery isolator, and winch contacter under my hood. Most items are going to be in places where they will be attached to the plastic panels. Winch contacter over by the factory ground, ground bus next to the air cleaner, isolator in that little indent behind the factory “tool kit”, fuse block behind the second battery.
How’s everyone doing this? Sheet metal screws right into the plastic seems easiest but may not stay secure? Machine screws with nuts on the back? Double sided tape?
Reactions: sharp
Jdiehl7
83
103
Houston
My screws are holding just fine!
Reactions: adnoh
ehart814
ehart814
1,701
3,889
NWPA
Good question... I have been meaning to ask this myself. I am most concerned about how to secure my second battery. How is everyone holding that down?
sharp
sharp
3,757
14,955
Tennessee
Industrial waterproof velcro, it holds perfect and no holes in the plastic.
Ohio4x4
Ohio4x4
I brought the dishwasher
1,535
15,490
I have nothing holding mine. It's the mighty max battery and with a little insulation tape it's a very tight fit. After dropping it in for the test fit I realized I should have put something under it to help pull it back out.
Reactions: ehart814 and sharp
ehart814
ehart814
1,701
3,889
NWPA
Good to know! I have the same battery. Thanks!
