P700m4 Shock spacer question
Ratchetdan
Ratchetdan
29
26
Alaska
New to the forum and thanks to everyone for all the awesome information posted. I've been spending all week reading all about the 700. I'm about 200 miles into a 2016 700/4. Not a crazy rider but I do like to have fun. I am having the same issues with many other posts about the front shocks bottoming out periodically. I like the spacer idea that has been presented in older posts on the 14/15 machines. So, my question is will the spacer option work on my 2016 700/4 and if so what size would you recommend for the fronts and possibly the rears..? (1/2", 5/8", 3/4", ect). Full disclosure, looking at putting a set of 26's or maybe even 27's soon so if that can be done with the spacer option - even better. Thanks in advance for any input!
allgm1
allgm1
1,049
1,484
New Hampshire
They mainly used spacers on the '14 models, in '15 they upgraded the springs in front to dual rate springs. The rears you can adjust yourself so no need for a spacer there. I'm pretty sure you can run 27"tires with stock suspension, I went to 26" on mine only because the tires I wanted only went up to 26. I put spacers on my front shocks ('15 model) mainly to gain back a little ground clearance I lost with the heater and winch installed in the front, I think I only did like a 3/8" spacer as I didn't want to give up any ride quality. The rears can be adjusted with a pair of channel lock pliers are preferably a spanner wrench, obviously the more you crank them up the stiffer the ride gets, I think I have mine on the second or third notch up from the softest setting
Reactions: swsebek
swsebek
swsebek
2,854
5,828
pa
I agree on A 2016,no more than 5/8 on front.I did the rears but removed them shortly after.jack the ride up and let the wheels hang to adjust the rears to a higher setting
sporttrac4x4
sporttrac4x4
1,177
2,082
ILL.
You can put 27 inch with no problems with or without spacer.
Reactions: swsebek
Ratchetdan
Ratchetdan
29
26
Alaska
Thanks all! I really appreciate all the input. I'll probably try 1/2" on the front and maybe give the rears 1 notch stronger. I gotta say, I really like this pioneer. Real easy to work out on and customize. I'll be posting in the near future of some switch/dash work and dual battery set up. Got all the parts on order. Hope to get to it within the next couple of weeks.
Reactions: allgm1 and swsebek
G
gokorn1
41
20
I went with a 1in on my 15 and it was a great improvement didn't notice to much lift. I also run 27in mayhem with not issues as of yet. Just put in my Can am shocks and haven't taken it for a ride yet.
Reactions: Ratchetdan
Ratchetdan
Ratchetdan
29
26
Alaska
Thanks @gokorn1. Yeh, I've been keeping an eye out for some Can-Am shocks myself. That's sounds like the way to go. I installed 5/8 spacers yesterday. Haven't had a chance to really test it out yet so we'll see...
Ratchetdan
Ratchetdan
29
26
Alaska
First off, Welcome.
My $0.02 is to get the commander shocks. I have them and love the stance.
I've read in here about a 2015 commander working with a bushing kit... is that the only year or will others work?
G
gokorn1
41
20
I see your in AK as well. Theres a set of craigslist going for $400 right now. Its a little high as I got a set for $200 but if your willing to wait he might come down. My trailer is still frozen in a snow drift but as soon as its out, we'll be testing the commander shocks out at Knik
Ratchetdan
Ratchetdan
29
26
Alaska
Found them. Thanks for the heads up. I sent him a message... we'll see...
7,139
27,144
I know mine were not from one that new. You can google search the part #s for the shocks. I do think they have to be XT's
