A
Yes, 2wd, but it does it in turf mode, too--just not as noticeable. Tires are a little low--8.5 psi.Are you in 2wd not turf mode?
Low tire?
You can see camera move with sound like a flat or low tire.
Just guessin
These aren't the Big Horns--they are the ones that come on the steel wheels. I checked the oil and subtrans fluid, which were fine. I'll have to figure out how to check the diff. I drove it elk hunting in Sept on dirt, but those were really bumpy roads, so I wouldn't have even noticed.Have you checked all of your fluids including subtrans and rear differential? If all of those look good it is most likely just the stock bighorns they tend to sound like that on pavement. Does it make the same noise on dirt?
Sent from my Pixel 4 using Tapatalk
I’ve had this sound before when I had a low rear tire.Are you in 2wd not turf mode?
Low tire?
Just guessin
Flat spot on a tire or 2 from sitting. Add a little more air all the way around and see if that stops it. Higher speed run will also sling em out round again. Tires been off recently, did the lug nuts fall back into chamfer? 🤷♂️Have you checked all of your fluids including subtrans and rear differential? If all of those look good it is most likely just the stock bighorns they tend to sound like that on pavement. Does it make the same noise on dirt?
I took one wheel off to allow me to remove the sway bar. I think it was the rear driver side. I guess I should check that out. I'm pretty sure we didn't bend a wheel at elk camp. Didn't do any fast driving at all. Mostly putted around.As stated above, did you have one off and remounted, perhaps the rim is not seated properly to the hub.
Or you bent a rim at huntin camp.
Thanks, that's helpful!That sounds exactly like what mine did with the stock tires on 12 wheels. When I replaced them with terrabites it was a night and day difference in how much smoother it went down the road and I haven't had that noise since the switch.
Good deal! It does sound quieter now. At least you know that it made a difference and that's what is making the noise.Thanks, that's helpful!
I remounted the two rear wheels (man were the nuts on tight!) and checked the rear diff oil (maybe 1/4" down from the check hole). I'm pretty sure that's not very low. And here was the results. I think it's better, but you can still hear some wah, wah, wah.
After remounting wheels
