P1000m5 Shoutout to whoever suggested Super Clean
Bubbadoyle
48
87
Lodi WI
Just wanted to say thanks to whoever suggested Super Clean. Don't remember where I saw it on the forum but my white 1000-5 deluxe is cleaner than I thought it would ever be again. Wasn't quite as easy as spray on and rinse off but spraying it on and a simple wiping with a rag (no scrubbing required) and it looks good as new. I did mix it about 50/50 with water. It was on sale for $6.99 a gallon at menards so it's cheap as well.
Upstatefreedom
Upstatefreedom
224
410
Colton,New york
How well does it work on the black textured plastic? Seems to always have that slight dirty look.
Reactions: sharp
66,871
I think that may been @joeymt33. I also use it and it works great.
It works excellent on the textured plastic and tires.
Bubbadoyle
48
87
Lodi WI
Didn't try to get that spotless. I did one small area below the drivers door and maybe wiped rag over it three or four times with very light pressure and then rinsed it off. I just went to garage and checked that area. It appears to be very clean.
cwalton
cwalton
Who has more fun!
334
724
West Virginia
I then coat all black and all underside with spray style tire shine. I wipe excess from external black and let underside just drip. Looks better than new.
Reactions: moparornocar
nbomar
nbomar
4,416
17,854
Springdale, AR
I use super clean too. I don't dilute it. Be careful on metal... I ruined my tonneau cover frame the other day with it...
Reactions: Upstatefreedom
Crap! That's bad stuff. I hope you don't blame me for recommending it!
Reactions: Eltobgi and sharp
Bad_bowtie
Bad_bowtie
Huge member
2,547
15,690
East Tennessee
I used it after our last trip to Windrock. Will be using it from now on! Thanks for the reccomendation.
Reactions: sharp
AlR
AlR
470
1,166
Nanaimo, British Columbia
I love SuperClean. I use it straight... spray on, scrub abit, sit, rinse off. You have to knock off the larger dirt chunks first though. I don't see many surfaces on P500 that it would harm.
Al
Smidgy
Smidgy
40
61
New Brunswick
I have always used superclean. I don't dilute. My process is this. General spray down removing 80%+ of dirt. Superclean an area then spray it down good. This will loosen up a lot of stubborn dirt. I then handwash with a car wash soap. Sounds like a lot of work but it isn't. If I want a like new shine put on it I spray on the maxima sc1
Reactions: sharp and AlR
Rayrule
Rayrule
91
293
53
Catskills Mts. NY
I have used simple green on the motocross bikes for years & that does a good job as well. Used the super clean once & like nbomar says not a very good outcome especially on aluminum parts. I guess if your careful with it. Oh well live a little & learn a lot..
Reactions: AlR
nbomar
nbomar
4,416
17,854
Springdale, AR
Something else I tried today that is absolutely amazing... SC1. It's expensive but holy cow this stuff is impressive! My rig looks pretty close to new... the scratches and discoloring are all gone. I've been told to spray down the undercarriage with it and the mud will just fall off. I bought a couple cans and it took 1 can to spray the entire front suspension and undercarriage and the entire body. I need to do the rear suspension and undercarriage with the second can.
596e0dbf945c46f95d171881306e6367
7d69a0f08d09b2162a79bb282adb5dc7
Smidgy
Smidgy
40
61
New Brunswick
This stuff is awesome, makes your bike smell as good as it looks too. Warning once you use this, your bike washes are going to cost you more money!!. Water does bead off of it and I find the next time you wash your bike it cleans easier.
Reactions: nbomar
AlR
AlR
470
1,166
New bike in a can! SC1 is worth the price.
Al
Reactions: nbomar
nbomar
nbomar
4,416
17,854
Springdale, AR
I can't believe how clean this thing is without putting a wash mitt or brush anywhere on it. Blows my mind. I've also always just assumed sc1 was just armorall in a can... it's nothing like it. It's not greasy or wet to the touch after it's sat for a few minutes.
49d00d3e7fe851f85107fc2f5807e60b872799fdf96bb4ded5a2268e90cab5f3
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Reactions: Eltobgi and nbomar
Smidgy
Smidgy
40
61
New Brunswick
What is really good is don't tell all your riding buddies your secret. They will ask you every ride it is hilarious to tell them "I just wash it". And thy will be like o.0......really
