Hi all! I recently picked up my 1000R and have noticed some pretty gnarly shuttering when doing even the slightest hill climbs when in 4wd. It seems to come mostly from the front and I'm just trying to get a better idea if this is normal?
Should I be driving it up steep hills in 2wd instead? I've been driving around mostly at the OHV Cinders park in Flagstaff and without 4wd on, you cannot really go anywhere due to how loose the volcanic gravel like material is. Other thoughts are should I be using low gear instead for these type of slight inclines? I'm not talking about doing crazy hill climbs but just casual hills on loose gravel.
What's everyone thoughts on when to use 2wd vs 4wd and high vs low gearing?
Here's a picture I took of a slight hill I was going up and started experiencing crazy shuttering. I hope this can give a better idea of the type of ground material and grade of hill. Going slow will just dig yourself into the cinders so you gotta give it some throttle. Hoping for some input on how one would approach this type of driving.
