P1000 Size of spacers for the front shocks
322,690
Hey I was talking to AK_C and got me thinking back to spacers for the time being to fix the shock issues. Can anyone confirm the spacer dimensions for the front shocks on the 1000?
66,870
Got my specs out...
Front seems to be 1.78" OD of shock. Better just say 1.8" OD.
It does not need much. I think 1/2" or 3/4" should be enough.
But you could jump up to as high as you want.
Drawback is... It gets stiffer the taller you go.
Now... To find a thick wall pipe that has that ID.
Reactions: CumminsPusher
322,690
Thanks for reply! Just trying to go enough to stop the bottoming out. I didn't even want to go the full two inches of lift that you can buy. Do you think half inch spacer will be enough? Because I'm a little concerned with stuff jamming up under. Just looking for a temporary fix I hope this will do till better shocks.
322,690
Ok done thank you guys very much!
amc019
amc019
480
592
Little Rock, Ar
How tall are the spacers you can buy off ebay? I too would like some to pick the front end up a little bit, but not a full 2"
322,690
Two inch lift was all I could find. That's why I was asking here to try to just get the bump out of the front end without jacking it too much and making it stiff, 1inch spacer is two inch lift. I plan on doing 1/2 spacers I'm hoping th all will be enough to fix it till I can hopefully go Fox.
amc019
amc019
480
592
Little Rock, Ar
Sounds like exactly what I am looking for, and also hoping for Fox to come out out with front and rear shocks. Guess 4 of us could go in on one of those 2" lift kits off ebay and cut them in half.
322,690
I was thinking the exact same thing! That's funny
322,690
I'm going to call around tomorrow a bit and find something. I tried all the home improvement stores with no luck. But there has to be someone that's got that.
322,690
Are you looking to do the rears with Fox too?
322,690
322,690
3od thick wall will be 2in inner?
322,690
Oh gotcha! Thanks again
322,690
322,690
Thanks everyone
