P1000m5 So, I almost killed my pioneer.
moparornocar
moparornocar
RIP....Rocmar...
4,606
12,493
Augusta, Wisconsin
Did nearly the exact same thing as @CumminsPusher did and hit a water hole at about 35 mph and killed it. Engine shut off right away, ashamed to say I got towed out of the hole by a Polaris 1000 atv. Once I got it up on dry land we pulled the plugs and turned it over until no more water came out of the exhaust pipe. Put it back together and left the intake hose disconnected to keep from sucking more water into the motor. It fired up, dumped about 2 quarts of water out the tail pipe and I limped it back 16 miles back to the truck. Oil is the color of Ovaltine but no knocking or ticking. Time for a full fluid flush and snorkel I suppose!
IMG 20160720 105450052 IMG 20160720 110318042 HDR
Reactions: pct and drfubar
322,690
Oh god! You got luck my friend! SNORKEL TIME! :) Was that the first water of the day?
moparornocar
moparornocar
RIP....Rocmar...
4,606
12,493
Augusta, Wisconsin
First and only. I hit that same hole last year with my Polaris and it was only half as deep then. I would definitely say I got lucky!
Reactions: CumminsPusher
322,690
polaris intake is different location.
You may have been ok because it was just one. We had been playing in the water all day and I suspect we added a little each time. Our puddle wasn't near that size. I'm really glad it's ok!!!
Reactions: moparornocar
322,690
Since its running just run cheap through it several times and fill back up good. I'm sure you're ok but flush fast so water doesn't start rusting crap up inside. I really am glad this turned out for the best. Btw I love the big window decal! Should have pulled it off while the other thing was pulling you:)
moparornocar
moparornocar
RIP....Rocmar...
4,606
12,493
Augusta, Wisconsin
It was a Sportsman to boot. Extremely fortunate that it survived. I'll flush it out tonight. I didn't even think about rust.
322,690
And a Sportsman! Grrrr. You just killed me a bit inside! Hours before mine took on water our Sportsman took its last breath with original motor at 2600 miles. Had it not I still wouldn't have towed it home with the popo. At least he only pulled you out and you made it back under power:)
moparornocar
moparornocar
RIP....Rocmar...
4,606
12,493
Augusta, Wisconsin
Exactly! It did run back under its own power! Lol. I had a Sportsman 850xp with nearly 4k miles. Sounded like marbles rattling around in it though the valves wee so loose
moparornocar
moparornocar
RIP....Rocmar...
4,606
12,493
Augusta, Wisconsin
Btw, if anyone wants one of the big Honda decals my local dealer has them, I'd be happy to ship one out if anyone wants one
moparornocar
moparornocar
RIP....Rocmar...
4,606
12,493
Augusta, Wisconsin
Was hoping to make it past the 500 mile mark at least before I had it apart this far, but here we are. 2 oil changes later she runs fine and the oil is clear again. Lucky we escaped serious damage. Next is a date with the awesome cleaner and a power washer.
IMG 20160720 223740934
322,690
moparornocar
moparornocar
RIP....Rocmar...
4,606
12,493
Augusta, Wisconsin
Thanks! Looking at the pics, any body have an opinion on if water got into the subframe or diff's?
