P700 Spare Tire Mounted to Front
DesertRat
DesertRat
25
23
Phoenix, AZ
Has anyone mounted a spare wheel on the front of a 700? I've been contemplating trying to get it out of the cargo area to free up storage and don't really want the extra weight on the rear. The 700 seems a little light on the front when fully loaded and I was thinking it could use a little weight up front anyway. Any known pitfalls putting a spare bracket on the front bumper?
allgm1
allgm1
1,049
1,484
New Hampshire
The nice part about the extra weight in back is you can adjust the shocks to compensate. For me the extra weight on the front would not be welcomed as I find the front suspension soft enough as it is, then throw the weight of a tire up there and I'd be bouncing the front skid off everything.
DesertRat
DesertRat
25
23
Phoenix, AZ
Good point, the front of the 700 bottoms out easily as it is - I'm thinking to mount the spare up front and replace the front shocks with ones that are adjustable. I just ordered a set of Fox1.5 PODIUM C shocks, which are supposed to be adjustable - hopefully, that'll allow me to redistribute some weight, free up some cargo area, and get a smoother ride.
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
They will. Good purchase!
Gator
Gator
The Most Unknown Member
2,475
10,396
Louisiana
Man I like that. I'd really like to see more pics of the mount and I'd like to see the tray.
Gator
Gator
2,475
10,396
Louisiana
Yep, I think I need to do both of these. I like the spare up there to help push through brush.
I have a plastic tote under the hood but I worry about durability. The metal is superior
Reactions: DesertRat
DesertRat
DesertRat
25
23
Phoenix, AZ
I also put a wide strip of the Velcro across the tray and the bottom of my tool bag to help keep it in place; and I wrapped the bag tightly with a couple of Velcro straps to help keep things from bouncing and sliding around. I didn't want it bumping the fuse box.
DesertRat
DesertRat
25
23
Phoenix, AZ
Now, it overheats after a few minutes of cruising at 43 mph!!! Probably, not enough air through the spare.
Gator
Gator
2,475
10,396
Louisiana
I have never had mine up to 43 for more than a few seconds. I just can't imagine how it could be blocking ALL the air.
Hmmmmm. Take the tire off and try running 43 under the same conditions.
Reactions: Tflynn
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
That sucks but kinda makes sense. At 43 she's giving you all she's got! So what could be a cure... All I can think is possibly get some kind of hood scoop or Louvers that direct air to the radiator, relocate the radiator (like dedicated mud trucks do), or put the spare either higher or lower, or just move it altogether.
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
Looking at your rig again, I bet you could mount some type of fins/deflectors/shroud type thing to the bumper on either side of the tire that would funnel the air back into the radiator
You get your fox shocks yet @DesertRat?
DesertRat
DesertRat
25
23
Phoenix, AZ
Good idea about the fins - I'll work on that. I did get the Fox shocks installed and they do make a HUGE difference - I'm still tweaking them to get the best ride, but they've already helped quite a bit.
Reactions: Tflynn
DesertRat
DesertRat
25
23
Phoenix, AZ
I couldn't get the fins installed, but it doesn't overheat if I keep it under 33 mph - I drove it a few hundred miles now in some severe temperatures, climbing some pretty steep mountains, and it did fine as long as I kept the speed down
Russel
Russel
69
83
Kodiak, AK
@ DesertRat, If you are not getting enough air, maybe drill some holes in the metal basket? The problem maybe not getting enough circulation. It will still be strong enough and with the airflow, you will have the water drain out as well, if you go through a creek or large puddles.
