P700 Spring Spacers
BadMoon
BadMoon
20
S.E. Michigan
So who has made spring spacers and what thickness did you end up going with? They are easy enough to make ,just wondering what size preloads the spring the best for you and why....I have made these in the past for my Rancher to help with plow sag and they worked pretty good.. I'll be making them and not buying them, thinking about 1 1/4" hoping that isnt too harsh and will stop bottoming out....it hasnt been out of the garage since we picked it up is why I am asking
thanks in advance
115,291
Again, Use the search up top….
Its been done many times.
Reactions: Rayger143
NorthernJoe
NorthernJoe
355
1,356
Northern Ontario
thanks in advance
I made a mechanical lift. If you look at the geometry you are gaining lift without changing the angle of the shock. There was no noticeable difference in ride quality
IMG 6631
