P500 Start in gear
Bridgie
46
61
Canada
Does anyone know the name of the sensor that connects to the back of the brake pedal to allow you to start in gear? Or better yet, an override so I can start in gear without the pedal. 837275845b56c6aa03435f30d363e055D0640fa1f11d3dd5894fc2af9464bc10E8937d285df9e3e120a89807fb2c6f03
Sent from my SM-A530W using Tapatalk
66,870
Do brake lights work?
Most likley tired into the foot brake switch.
Bridgie
46
61
Canada
Nope, brake lights are out
Bridgie
46
61
Canada
There's second spring on the brake pedal has a little connection it fits into.1ef60725163cb61b8886d2d0f79017937faa8f8d93c51c46503dbfc77b5f14bf
66,870
Uses same sensor looks like.
Was looking at the wire diagram.
Have to figure out alog as you have the neutral diode. Brake inhibitor. And an second diode to figure out.
Bridgie
46
61
Canada
Yeah I just figured that out. Don't want to lose the brake light so it looks like I'll have to replace it. Poplar twigs are vicious
Bridgie
46
61
Canada
Have a part number by any chance?
Bridgie
46
61
Canada
Thanks a lot, that's awesome.
Bridgie
46
61
Canada
The nearest dealer is 3 hours away so that'll be a help for sure. Now do you have a fix for my second gear being a dash and the auto shifting not getting past second gear ?
66,870
If the gear position sensor is not sending the GEAR2 single. I assume it will not go to 3.
Sensor is behind the motor.
Connector looks like this behind the battery box somewhere.
All are ground triggers telling the computer what gear it is in.7796991f2f35c8b4e558502c4a05478b95b69b7becefb7a0221182bd5266f280
Bridgie
46
61
Canada
It'll go to 3 manual but won't shift to third in auto.
Bridgie
46
61
Canada
Thanks for the help
