I've seen one with a sheet metal roof that looked good. But he built his own cage too. Building an aluminum roof is on my to do list but it's pretty far down on it lol.
1/8" steel full roof would weigh close to 200# and would be pretty overkill. One thing to check also is how wide you want it. I think the stock cage is close to 62" wide and most metals are 48" or 60" wide.
Yea I had a feeling what you guys might say because I kinda felt the same way. Well, the only thing about aluminum is it shine's so bad. I did it once before and painted it black but every tree limb would scratch it so bad. Any ideas of this?
You'd have to coat the steel anyways. Some paints aren't direct to metal meaning they don't adhere too well to bare metal especially aluminum so read the labels.
Spray can bed liner from Walmart is reasonable and probably be good that job but make sure the panel is sanded or scuffed well no matter what's used and use petroleum based cleaner (acetone, lacquer thinner etc) before paint
