P1000 STI HD9 or Raceline Mamba wheels 6+1 offset.
Sjc3081
Sjc3081
263
442
Wappinger NY
My 5+2 wheels make my machine to wide. 67” front and 66” rear. I'm considering using 6+1 offset on all four corners. Anyone run 6+1 on all four. Im not sure if I should run HD9 or Raceline Mamba. Im partial to the HD 9 due to the bolt on center caps.
Reactions: BWAF and Isaiah
sporttrac4x4
sporttrac4x4
1,177
2,082
ILL.
I run 6+1 on all 4 works great
Reactions: Isaiah
sporttrac4x4
sporttrac4x4
1,177
2,082
ILL.
27x9x14 front 27x11x14 back ,STI black diamond XTR STI Hd 3 14x7 6+1
Reactions: Sjc3081
208,029
My 5+2 wheels make my machine to wide. 67” front and 66” rear. I'm considering using 6+1 offset on all four corners. Anyone run 6+1 o when they get worn.n all four. Im not sure if I should run HD9 or Raceline Mamba. Im partial to the HD 9 due to the bolt on center caps.
If you want stock width, run 6+1 on the front and 5+2 on the back. If you mostly trail ride, who rotates tires, I rotate mine into the dumpster!
208,029
5+2 rears increase rear width to 66” from 63”.
The rear is 2 inches narrower than the front from mating surfaces of the wheel. Stock wheels 1+? front and 2 +? rear is the stock offset. The stock rear rim is a 2+ ? for wide rear tire, all of the width on the stock tire goes to the inside, I've done this, I'm no wider on both ends than stock, call Race Line Wheels and tell them what you want to do and they will fix you right up with the right info, I did after many hours of calculations and they confirmed my research, ordered the wheels and perfect, stock width.
208,029
Whoops think I said that wrong ?+1 and ?+2. Any way call Race Line Wheels.
208,029
Smitty335 I will call them thanks.
You are wise Grasshopper! Not all mgf's make different off sets, Race Line does. My Honda dealership noticed my wheels RL and are now stocking them. Good wheels. And my bead locks don't leak?
