for those looking at 14" STI Hd9 wheels, I have them installed now with 30" Maxxis Liberties. I am 69" wide from & with 1.5" spacers I am 69" in rear. The inside of the front wheels is very close to the Brake rotors. I may build some 1/8" to 1/4" this spacers just add a little more clearance. They Do NO HIT, but close.
i notice a little of the same effect I have with the setup on my YXZ. The car wants to go back straight when you let go of wheel. Not bad, but a different feeling from stock wheel & tires. I don't think it is an issue, but noticeable. My be what others are calling "Heavy"??
I don't see any huge power difference, but have not done more than around the block to settle in for measuring.
If I had not already had the 30" tires, I would have gone to 15" wheels for extra inside wheel clearance.
Just a note, I got my rear wheel spacers from a friend. They were right spacing, but had 12 x 1.25 studs. Work fine, but now I have 2 different thread lug nuts. If ordering, keep that in mind as when I was looking, not all had right stud threads
