seems likely water in the mechanism, they are not meant to be in temps or any moisture. dielectric or silicone is fine but not wd-40 it is a water attractant. you spray anything with wd that's going on a bike that's always in mud or snow it wont last long. battery spray or something like that is the best thing for electrical parts
Amazon?Just ordered the cole hersee that @Neohio suggested. I guess 65 amp is sufficient?
Yep..Amazon?
stuff looks interesting and about the same cost I might. the grease looks interesting too seems like that would be good for cold weather property in servicing tractors and quads around hereTry this stuff if you get a chance... you will be amazed.
Corrosion Technologies makers of world famous CorrosionX and RejeX
FredD
Yep..
Cole Hersee 24117-01-BP 12V Continuous Duty Solenoid (4 Stud Hex Nut 20 Ul) https://www.amazon.com/dp/B001Q8KONI/?tag=sxsweb24-20
@RedFred1 -- Does the Tyco cube relay allow you to switch it on/off?
if you wanted to use a switch for the above relay you get a single throw doesn't much matter amp rating, one side to +12v other side of switch to tab he labeled coil 85 ground 86
So I would take the two battery cables off my stinger relay put them on the larger screws (load), then the smaller wires coming from my switch to the "coil 85" spots?
I am not running this exact product but the one I am running looks exactly the same (gray PVC dipped relay) I got mine at the local marine store up here in Alaska. It’s been through 2 winters so far and LOTS of water (my P1K-5 is my trail boat) no issues summer or winter.... so far.My Stinger froze up on me this weekend for the 3rd time. I am done with it. Generally when @Neohio recommends something its good, but wondering if others have had experience with this solenoid in colder climates? I am usually using my machine on the ice while fishing or plowing snow so its important to have my 2nd battery work properly and I want the switch on power.
Thanks,
JR
