nitzo
Has anyone had this issue? I've done a pretty good search and have found a lot of folks on the internet are having this happen. I'm just wondering if anyone on this site has had it happen.
Today I mounted 28" Berserkers on STI 12" headlock rims. I installed the tire, tightened the ring down (in a cross pattern) handtight. I set my torque wrench to 12 ft/lbs. and started to tighten the bolts. Well, I ended up stripping out 3 bolts on the first tire. I backed the torque wrench off to 10 ft/lbs and tightened the rest without an issue. I found tightening with a 6" ratchet almost as tight as I can is about 10 to 12 ft/lbs. I did the other 3 tires this way, and didn't strip any. I feel they aren't quite tight enough, but am afraid to tighten them more. I guess I'll just use them the way they are, checking often for looseness.
Those that are using these rims. What have you found? How tight are you tightening them? How did you fix them if it did happen? Any input would be great. Thanks.
