P1000 Stripped threads?
kjw83
kjw83
61
30
Madisonville KY
while attempting to reinstall the bottom bolts on the front bumper of my P1K5 after installing my winch, I believe I have stripped the threads that the bolts goes in to. I used a KFI mount and they supplied longer bolts to use in place of the stock bolts. The holes on the mounting plate didn’t like up exactly square but enough I could get a bolt in.....Is it possible to rethread it? What exactly do I need to do this? I’d rather not take it to a dealer if it’s a fairly easy fix......suggestions please?
7,588
31,356
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Was it one of the horizontal bolts? The ones that go through the frame? Sorry no pictures.
7,588
31,356
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
I think I used 1/4" bolt.
I had to use what I had.
kjw83
kjw83
61
30
Madisonville KY
It was the bolts on the very bottom of the front bumper.....there’s 1 on each side....I believe that the nut it threads in to is stripped....once the bumper is installed there’s no access to the backside of the bolt.
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
If it's very bottom one on each side I'm pretty sure it's a m10x1.5. As Tram suggested, run a longer bolt through and add lockwasher and a nut. That's what I did also.
ToddACimer
ToddACimer
Pioneer 1005-2
3,805
16,192
Oshkosh, Wi
Alternatively the m10 nuts only have 2 tack welds on them. I had one of my nuts break free. You might be able to just knock the nut off and weld on a new one.
Reactions: Jankyeye
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Those bolts are major pain to get started. No wonder several have had trouble with them.
Reactions: ToddACimer
211,099
Trade it back in, HA! Get a tap and new bolt.
Huntnbuddy2
Huntnbuddy2
192
663
Sand Mtn
I had the same problem, just cleaned the bolt threads and then used a 10 x1.25tap to re thread the hole and then made sure they lined up and reinserted the bolt.
Reactions: Tramguage1
Someguy
181
179
Krakow Wi.
Do this, then what I did was to is drill a slightly larger hole in the kfi mount to get the bolt started, if needed add a washer, but don't think you will need a washer
Someguy
181
179
Krakow Wi.
If. Remember correctly it's only one hole that is off.
Just-Snake
Just-Snake
6
Iowa
20250403 174143
Reactions: rockremoval
rockremoval
70
179
Similar problem and did exactly what you did when mounting up my kfi plow frame. The hole alignment wasn’t perfect on 1 hole and it appeared the threaded hole through frame had weld splatter in all 4 threaded holes so chased em all out before mounting. I’m willing to bet the OP could probably chase them out if they aren’t completely mangled.
Similar threads
