P700 Strong 2.5 lift
N
Newhonda
Arkansas
I am a new Honda owner, switching from Polaris. I installed a Strong lift last night and was reading the instructions and noticed it mentioned adjusting tie rods. Did any of you guys who installed this lift have to make adjustments? My 27's will be in later this week and I want to get lift on before I install the tires.
thanks in advance
Reactions: Russ989
It’s gonna change the toe-in, a few mins with (2) 4’ levels and you can get it fairly well adjusted.
Reactions: Russ989
N
Newhonda
Arkansas
Thanks, Do i need to make the adjustment with the front end on a floor jack or on the ground?
Reactions: Russ989
Russ989
Russ989
22,639
147,230
thanks in advance
@ohanacreek has put you on the right track, congrats on your new pioneer and welcome to the club. This is the best forum hands down for resources regarding your new purchase.
Reactions: Mudwing
Cyberjunk
Cyberjunk
Berserker
1,622
6,078
Crane Hill Alabama
You need to add wheel spacers to offset the higher center of gravity. I made my own lift same design as the strong ones, had them on mine along with can am shocks. Took the lift off after I got my 27 inch tires. The can am shocks give you 2 inches of lift as well as a Hugh upgrade in ride.
