P700 Sudden engine shut down
BigMac
BigMac
48
92
After extended slow speed operation engine stopped.
Been using oil had checked a few days ago. Engine seemed hot but did not check gage. Oil was not registering or so clean could not be seen. Electric fan came on and stayed on extended period and also saw yellow engine light come on momentarily.
Looked over engine for oil or water leaks could not see problem but it was hot.
i let it cool a while then was able to start go back to barn. Engine light did not come back on.
Stopped and got some wet clutch oil and gold antifreeze at O‘Reilly‘s.
I will check oil and antifreeze tomorrow.
106,244
Had to take it to St Joe Honda. Had a complete service done too. Problem was a connector wire To fuel injector? Coming home tomorrow.
How many miles on the rig?
Reactions: Smitty335 and Coeus
106,244
I am uncertain. I can check later. Been run daily for 7 years. Lots of hours and lots of miles.
Yeah, would be interested to see that. Makes a difference with your issue.
Dont forget to hit “reply” then respond to a question or the questioner wont know u answered. ;)
BigMac
BigMac
48
92
2000 hours
Chris at St Joe Honda found fuel injector connector at fault. Cleaned pins and tighten corrector solve the issue.
HBarlow
HBarlow
1,618
6,010
Daniels, WV
Is the Honda Pioneer 700 engine a single cylinder?
Jerryg
Jerryg
10,678
86,355
NEPA
Check the gas cap for venting and the spark arrestee,
Try the easy stuff first.
