Are you going to be removing a rocker switch blank (plastic snap in cover that you remove to reveal switch hole), or are you cutting a new switch hole?
No doubt you will want to use the rocker switch to apply power to energize a relay, which in turn will then switch power to the light bar, unless the light bar is relatively small. The rocker switches are supposedly rated for 20 amps, though that's more than a stretch.
