Switching to i4wd while moving?
Jhn_mcdngh
9
11
Ridgecrest, CA
Does anybody have any info on how it is on the machine when you switch into 4wd while your moving?
I have a 2021 1000r live valve and I have gotten mixed reviews on this topic. Just looking for some insight.
NTCPrezJB
NTCPrezJB
President of #NTC
100,995
902,253
Canton, OH
Answers are going to vary wildly on this one.
If the driveline isn't moving when you engage 4WD then the engagement can't cause an issue. If it is moving...there are circumstances where it definitely can cause an issue. If you feel you have the confidence to know that everything is spinning at the same speed when you hit the button then go for it, but personally I don't shift into 4wd on the go. It's a risk/reward scenario in my mind. I can spare the few seconds to stop before I engage 4wd so that I don't have to fix something because I didn't.
7,145
27,191
I go back and forth from 4wd to 2wd on the fly. I always let of the throttle before and after i switch. I have noticed if you switch to 2wd while in the throttle it will not disengage until you let off the throttle.
Sheetmetalfab
Sheetmetalfab
2,017
12,312
Alaska
Yep I switch on the fly with a momentary throttle blip as needed.
906UP
906UP
13,064
121,882
da Yoop
From the owners manual, page 35. If the speed difference is greater than the ECM will allow it won't make the shift, blip the throttle. Unlike the P5 which is connected to a lever/cable, the i4wd system is computer controlled.
I4wd
5,039
22,566
#metoo I try to unload the driveline before going to 4wd but I'm sure I've done it loaded too and have never heard any angry clunking when I do. When in 4wd, I have a definite lite howl that won't quit when shifting back to 2wd until I blip the throttle - it's very obvious to me.
McCarthy
267
537
Canada
I've tried shifting from 4wd to 2wd while moving and it won't indicate it's shifted until I come to a stop.
Reactions: TimG and rtn001
320,204
I’ve always shifted the manual diff lock rigs whenever, most all I know and ride with do as well, however you just need to make sure you’re not spinning, I just slightly lift off the throttle exactly like an old truck. Did that with all my machines, broke a lot of crap over the years but nothing because of shifting on the fly.
But ya never do I stop first. Some say that was a benefit of I4wd because you could shift without coming to a stop. So it should be even safer.
PaulF
PaulF
1,462
4,810
Switch whenever you need. If the ECU senses too much difference in F/R wheel speed, it won't engage until the difference is within tolerance to avoid damage. I engaged mine at 40 mph all the time at the dunes when I know I will need it, never had an issue.
It also tends to not disengage when accelerating or decelerating but will eventually when you change throttle pressure.
PaulF
PaulF
1,462
4,810
You will never hear a clunk or grind or any gear to gear type noise on a Talon when engaging i4WD. The engagement is an electric "clutch" type mechanism, not gear to gear engagement. That is why you can seamlessly shift the Talon on the fly.
McCarthy
267
537
Canada
If I disengage while moving it will never shift into 2wd until I come to a stop, doesn't matter if I am off the gas coasting down a hill, or just cruising or whatever. Wonder if something i wrong with the i4wd?
EDIT: I'm an idiot, it is changing properly, I just need to touch the gas for the diagram on the dash to show it switched.
PaulF
PaulF
1,462
4,810
Mine goes in and out of i4WD seamlessly at any speed. Sometimes I need to change throttle pressure but it has never failed me. So either I have a "special" Talon or there is something wrong with yours.
Sheetmetalfab
Sheetmetalfab
2,017
12,312
Alaska
I think you have something wrong.
I go in and out multiple times as i drift corners then climb hills and it’s seamless
WillyBill
WillyBill
Wheeling Addict
473
1,887
Clinton, Utah
  1. Talon X LV
Honda recommends running in 4XD whenever off the asphalt.
WB
L
LincolnSixAlpha
21
44
Arizona
I've been flipping it on and off as needed while under acceleration on flat surfaces at most speeds. The system never seems to complain. I don't use it on any hard-pack surfaces, only loose stuff. And never on asphalt.
Reactions: CID
