T - 6 days. Still so much to do!
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
Got several things I still need to do but took time to work on a set of sliders. Just had enough material.
IMG 20180414 103238887 1336x752
Did get my new tip installed.
IMG 20180414 122740983 1336x752
Last night I installed my 2" wheel spacers. Took it for a ride down the road and difference is amazing. Can easily take curves 10mph faster with 10 degrees less lean.
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
My bandsaw spit out a couple guide bearings so finishing those sliders is in jeopardy.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Just the tip?....
Is there a "lean-o-meter" for this?....
Reactions: GlockMeister
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
Really made that big a difference? What size spacers?
Yes it was huge. 2" in rear. My 1" for front will be here Tues. Same curves near home I used to lean to 20 degrees at 35mph I can now take at 45 with 10 degrees. It is night n day difference.
Ok.. I’ve got some inch and half I’ll give a try. May just bring them with me and put on at Takeover so I can get a feel for the difference.
And the only change was that of the spacers?
Reactions: Plumber32
66,897
I'll have a jack and impact
Reactions: JTW
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
You'll tell it I guarantee you. By far the most noticeable mod I've installed. Anxious to see if adding fronts will make much difference.
