TALON 1000R FRONT-END BRACE KIT
SuperATV
SuperATV
1,351
9,391
Madison, IN
www.superatv.com
TALON 1000R FRONT-END BRACE KIT​
Link: https://www.superatv.com/honda-talon-front-end-brace-kit
Honda talon 1000r front end brace kit 01
Honda talon 1000r front end brace kit 03
Honda talon 1000r front end brace kit 04
Honda talon 1000r front end brace kit 05
Honda talon 1000r front end brace kit 07
Front-End Support
You didn't invest in your Talon to sit back and watch everyone else rock crawl, mud dive, and blaze through rough terrain. Get in there and ride with the best of them knowing SuperATV's Honda Talon Front-End Brace Kit has your back. Are you worried about your Talon's weak spots? Our front-end brace kit will increase the longevity of your suspension parts, reinforce your A-arms' mounting positions, and strengthen the weak points in your shock tower. With this front-end brace kit installed, you can ride as hard as you want knowing your Talon has the support it needs.
Heavy-Duty Construction
We know the rugged terrain you're up against, so we've designed this front-end Talon brace kit to handle the abuse. We cut it 3/16" thick from heavy-duty steel plating—this front-end brace kit will hold up no matter how violent the trail gets. And for extra durability, we've added our UV-resistant powder coating to fight off rust and corrosion. Plus, it's easy to install. You'll be challenging your buddies on the roughest terrain in no time.
  • Made with 3/16” heavy-duty steel plating
  • Reinforces your A-arms' mounting positions
  • Strengthens weak points in frame
  • UV-resistant powder coat finish
  • Easy to install
  • Honda Talon 1000R : 2019+
60,302
Front-End Support
  • Easy to install
Does the big plate reinforce the front lower arm tabs and the lower bumper mounts? Didn’t see any photos of that piece
SuperATV
SuperATV
1,351
9,391
Madison, IN
www.superatv.com
60,302
SuperATV
SuperATV
1,351
9,391
Madison, IN
www.superatv.com
Yeah, I get that. I'm talking about this dude:
COME ON MAN
Finally got to go out and check it out in the shop.
I think you're referring to the section circled below...
Nc ohcuMrbWYnQ814AX sdmsz nc htscontentfind1 1
The brace does not bolt up there. That would be part of the winch mount brace that goes across and bolts to both sides. The big flat piece mounts to both of the side A-arm brackets, and is attached just above the bracing above the diff.
60,302
Thanks! I see it now, it's what ties the upper pieces together 👍
I was referring to this lower bumper mount that gets smashed all to s*** because it is made of cheese, which is why I was wondering how that was going to do anything to help 😂:
1664312410605
1664312452565
1664312468117
115,388
Front-End Support
  • Easy to install
Did u acually write this up? Its really good! All your missing is the audio and the god like reverb in the background 🤣
1664315733896
SuperATV
SuperATV
1,351
9,391
Madison, IN
www.superatv.com
SuperATV
SuperATV
1,351
9,391
Madison, IN
www.superatv.com
Oh no....you know they won't let this long haired hillbilly write the copy. You've seen some of my posts....
The TALON FRONT END BRACE
- Adds 22 HP
- Made out of billet adamantium (Marvel ain't gonna like that one)
- Jumps out of the box and installs itself in minutes!
- Makes your front end stiffer than any blue pill ever will
- Drops all the panties within a 3 mile radius!
TripleB
TripleB
15,161
135,293
Caryville, Tennessee
HondaTech
