Damn, a used 2021?
An occasional Talon has spit the caps off the driveshaft u-joints. Honda doesn't offer the u-joints separately but there is an aftermarket u-joint available.
Thanks to TerryH IIRC-
Moog 338 is a Talon u-joint replacement
Free Shipping - Moog Premium U-Joints with qualifying orders of $109. Shop U-Joints at Summit Racing.
www.summitracing.com
This might help too -
Hometeam about driveshaft replacement -
Well you definitely don't need to follow the service manual on how to replace your front prop shaft / drive shaft. I replaced mine with my machine sitting in the shed. I did not jack it up or remove any wheels or axles. Once you get the floor board and side cover off on the driver side, which feels like it has 9,000 plastic rivets!
At that point all's you need to do is remove the two safety loops and the three bolts that hold in the front diff. With the three bolts removed on the front diff that gives you enough play to remove the drive shaft. You will need to remove the front portion from the front diff first. It is shorter than the rear and you will have enough room with the play in the front diff to pull it out. The retaining clip on the front diff is a pain and was the hardest part of the easy job. If you didn't have to remove the plastics to access the drive shaft it would take less than an hour to do. Hope that helps if anyone has to do their own drive shaft.
