Talon - HondaSxS seat belt bypass
63,543
Shhh, don’t tell Honda or my son, but I spliced my seat belt harness to a toggle switch and mounted it low and rearward on the tunnel so he can drive the machine and I know he is limited to a safe speed. It lets him go really fast right up to the speed limiter
That's not a bad idea.
A key of some type for speed limitations.
Off - normal mode.
On - seat belt line inteuputed.
Reactions: Tramguage1
popeye
popeye
3,273
14,641
kapowsin, Wa
Off - normal mode.
Yea, it works for us. He loves driving it, but he’s only nine. He’s a great driver below 20 mph. I would let him have free reign on the property in the pioneer, but the talon is a tiny bit different. He drove 14 miles during a poker run in the sand last spring. I don’t even think he has hit the speed limiter yet, he’s a little bit scared of the machine. But he did drive over the wheel barrel that I forgot to put away
7,139
27,144
Off - normal mode.
Im in to test one of these! a hidden switch in the bypass loop wire?
Reactions: popeye
Ezgoin
Ezgoin
135
147
Pacific Northwest
That’s a great idea! Too bad someone doesn’t make an ECU flash that allowed us to gradually raise the speed limiter so we could gradually raise the seatbelt limiter for jr drivers! As it is, someday your son will lose toe 15 mph limit and jump right to the 75 mph limit!
Ezgoin
Ezgoin
135
147
Pacific Northwest
I received my HondaSXS seat belt bypass this weekend and it is a quality product. I wanted to do a bypass and still be able to go back to my stock seat belts if I wanted. This is the solution so you are not cutting wires or adding a belt clip. This is a plug and play item that works very well.
Here are some pics of the bypass and the new seat belts.
Here's the link - Harness accessory seatbelt bypass kit - Honda Pioneer, Honda Talon
Thank you HondaSXS
View attachment 119150 View attachment 119151 View attachment 119152 View attachment 119153
Looking at your bypass adaptor pics and trying to get a sense for exactly we’re that is on the Talon. I installed harnesses over the weekend but haven’t yet received my bypass adaptor so I just left the driver’s side right belt buckle assembly connected until my bypass gets here. Is that adaptor inside the center console?
63,543
It's under the drivers seat. Just follow the wire. You cant miss it.
Ezgoin
Ezgoin
135
147
Pacific Northwest
Installed my bypass today. Was a bit of a mutha getting the factory plug undone! Also, I had to take a razor blade to the bypass plug and trim off the two molded raised guides because they didn’t match the female end of the factory plug and prevented the bypass from fully engaging in the factory plug.
63,543
Installed my bypass today. Was a bit of a mutha getting the factory plug undone! Also, I had to take a razor blade to the bypass pqlug and trim off the two molded raised guides because they didn’t match the female end of the factory plug and prevented the bypass from fully engaging in the factory plug.
Humm.
What year and model do you have?
Connector should been the style on the right.
I have had no other reports of problems. So if something is wrong I need to figure it out. Any help would be great.
Thanks.
Code54
Code54
583
626
Hurricane West Virginia
Just for reference - I also installed the bypass today on a 2019 Talon X -- in my case it fit perfect and took about a minute to "install".
Reactions: 906UP
63,543
Thanks.
I can assume a change or I sent the wrong one. I dont claim to be perfect by no means. I've made many of build/shipping errors. Lol.
Reactions: 906UP and TripleB
bionicman
37
49
seattle
I just cut the factory wires & soldered together = done
Reactions: popeye
906UP
906UP
13,006
121,231
da Yoop
Same here, plugged in and done. Easy peasy!
like2be
like2be
16
17
Socal
Great thread, can someone please tell me how to disconnect the plug at the override before I completely destroy it. TIA for you advice.
13,350
64,947
While not a talon, but a Pioneer, Member @Russ989 did a nice little video for you.
Talon plugs are opposite of Pioneer if I recall correctly.
Ezgoin
Ezgoin
135
147
Pacific Northwest
I’d like to give you a simple trick to get them apart, but I gotta tell yah I fought mine for an hour before I was able to get it apart. Prying it with flat tip screwdrivers, pinching tabs, incorporating my wife’s help, and bloodying my knuckles before it finally came apart! Patience and perseverance!
63,543
See video above. Jump to 3:50 mark.
Once you see how it works... it's easy.
peekaa
peekaa
So Cal
Hi, Im just about to go pick up my talon 4 Fox live in a week. Im looking at some pro armor 3in 5 pt harnesses. Is there anything I need to know about mounting these other than needing an override plug. Seems by the pics the rear seats are not just mounting to a bar such as in the front??
Thanks
pk
