Talon ice crusher heater
RampageRhino
RampageRhino
99
263
Just giving anyone a heads up on the ice crusher heater for the talon. I am privileged to be working with ice crusher team to help modify this heater kit to work with a dual battery setup. more info coming soon!!!
sspeederr
sspeederr
391
661
I an not familiar with that brand but personally I have installed several inferno heaters with secondary battery supper simple modifications however Goodluck be nice to see a kit sold direct to work with out the extra hassel
Reactions: Buggyman
Scoop
Scoop
4,223
15,797
  3. Talon R LV
As opposed to the Inferno and many others that are installed under the drivers seat, the Ice Crusher installs behind the dash in an otherwise unused space. This mounts the unit higher in the bike (think fording through water) and also leaves that space under the seat for other uses.
EDIT: Sorry, just noticed this is a Talon thread. My description was for the Pioneer 1000.
  • Haha
Reactions: sspeederr
sspeederr
sspeederr
391
661
Ya the inferno for talon is located under hood between shock tower for units with electric wiper or live valve and for base models non live valve no wiper goes under cowl attaching to frame cross bar next one I do I will s ap pics
Reactions: Smitty335 and Scoop
RampageRhino
RampageRhino
99
263
They do offer them for the pioneers as well
HolySmit
HolySmit
15
40
Iowa
Scoop- Have you tried adding the new Aux water pump kit for the Ice Crusher heater on the Pioneer 1000-5? I'm deciding between the inferno Maxx and the Ice crusher for my buggy.
Scoop
Scoop
4,223
15,797
  3. Talon R LV
Yes, I installed the water pump in lieu of the MaxStat. The pump circulates coolant all the time at full rate, even when the machine is at idle. Also, even if there is only a hint of heat in the coolant, it's better to circulate that then have to wait until the machine comes up to temp and thermostats start opening. Scott @ Couper's Products said they will likely make the water pump THE option (over the MaxStat) for many kits. Call them and ask to talk to Scott - he installs these heaters for customers who bring their rig to them.
Prntckt
Prntckt
1,049
7,225
Altoona, WI
After a winter season with the heater, do you think the circulation pump is the ticket? I have the MaxStat, and it works pretty good. I’m wondering if the circulation pump would make my system better.
Scoop
Scoop
4,223
15,797
  3. Talon R LV
@Prntckt, I wish I could say I put enough time on it this past winter to give you an answer. With my buddy losing his brand new bike in the fire and a variable plethora of other things going on, we didn't see much seat time.
Code54
Code54
583
626
Hurricane West Virginia
Factory heat, AC, All wheel drive, and available factory turbo - This Talon already has it all......
