hondabob
We have some new Talon owners so its worth posting this info again.
We have to stop to shift. It only takes a split second to wiggle the shift lever forward and aft in the shift gate to make sure its fully in gear. It should be centered in the shift gate. If its loaded forward its not in gear and the display will have the --- instead of a R, H, or L. I think the gear dogs can line up occasionally. The Pioneer 1000 may do it every 4,000 miles but the Talon may do it every 400 miles. It may be that there is more Spring in the Talon shift cable. All the shift gears are the same. If its not fully in gear taking your foot off the brake may help or just shifting out then back into gear usually works. Shifting quick helps too. If I remember right the owners manual talks about this on page 33.
We have 10 Talons in our group. My buddy had the shift bang a couple of months ago. I told him how to avoid it. Yesterday he backed it out then shifted into low to load it on his trailer. When he applied throttle it went BANG as it slammed into gear. He thought he broke it. The sub trans is tough and can a lot of that but it is annoying and may eventually cause damage.
