Talon turn signals
Code54
Code54
585
635
Hurricane West Virginia
Seeing WV has passed the laws allowing me to register and plate my Talon I need to add turn signals (I already have the other stuff).
Any suggestions on a nice set or a plug and play that works good?
Thanks
Reactions: ProudDadOf5
ProudDadOf5
ProudDadOf5
3,122
24,208
Winfield, WV
Thanks
He dude, I must have totally missed this news flash!! 😳Hope all is well with you & the fam. Any word bout the P1K5 being street legal buddy? 🍻
Code54
Code54
585
635
All is well - we still need to get a WV ride together after all the COVID stuff passes.
Here is a link for everyone to the new law:
  • Love
ProudDadOf5
ProudDadOf5
3,122
24,208
Winfield, WV
We’ve been hittin the outlaws hard. Went to old carbide camp 2 weekends ago. Put bout 80 miles on the 🕷in one day. Queen shoals area, I’m sure you know where I’m talkin bout. As soon as this is over or the next time we go I will hit you up & see if you wanna ride. 🤘🏼
284B31F5 28C8 4858 A363 D49B939724D1
3D81349E D475 46E2 95D2 C5235FDC7BC9
8019D7AD DC85 42DE 99EA 0CED9A27EFFC
5,425
24,913
Ryco has a nice turn signal/horn/license plate light kit for @$300 that's all plug and play. It uses the stock brake lights and adds front turn signals + running lights. The instructions call for all 3 front bulbs facing forward but several of us put one on the side for better visibility.
1591062390716
HUCK
HUCK
1,047
2,319
ARIZONA
XTC HAS AN AWESOME PLUG & PLAY TURN SIGNAL SET UP
5,425
24,913
To add - the only clunky part of the Ryco kit is the turn signal stalk. It's probably what's available off the shelf and used in many applications. It hangs below the steering wheel but it's never been in my way, it's in the same position as my vehicles, so intuitive. It also contains the 4 way flashers and the horn button is on the end of the stalk. If you don't mind your signals and horn being switches in the dash, those are also available.
I ZQbWDTn M
Code54
Code54
585
635
Code54
Code54
585
635
Found a set on Ebay for $40 with switches, signals, relay, pretty much just add wire. I should have it this - I will post a follow up, hopefully decent.
Reactions: ProudDadOf5 and CID
Sheetmetalfab
Sheetmetalfab
2,172
13,598
Alaska
Link?
Code54
Code54
585
635
Reactions: Sheetmetalfab
T
Tlustre
AZ
this is the kit that i used. just be aware that you will need additional wires, butt connectors, etc. the wires supplied with the kits are not really long enough, especially if you have a 4 seater.
Have a link for those?
Sheetmetalfab
Sheetmetalfab
2,172
13,598
Alaska
  • Love
Reactions: Montecresto
Do you know if this kit is long enough for the X4 and includes a trailer plug...?
Edit, never mind, I see that we use our own wire and cut to length. Thanks
Code54
Code54
585
635
Started wiring mine in, simple so far. Made some mounts for the rear signals so they are out of the way yet visible from the rear. I will have about 60 bucks in it when done so not bad price wise and everything is looking good for a nice clean install. I snap some photos when I get done.
Now, where do I put the license plate and light.....
5,425
24,913
My plate frame fit like it was supposed to belong there, on the stock plastic exhaust cover. I don't have a plate yet so no photo, still in the box but drilled and ready for installation.
Do you have the lighted plate frame? Wondering if the heat will have effect in the wire and light...
5,425
24,913
I don't think it will, the exhaust cover is plastic after all. The wiring is anyone's guess but the plastic insulation lives lying against motors in other vehicles so I think it will be OK. @Lil_Steve has his plate mounted in the same place I plan on using, maybe he'll let us know if the wiring is holding up. 🤔
