Talon Talon upper doors
popeye
popeye
3,273
14,641
kapowsin, Wa
So got mine installed tonight, in my back yard, it for dark befor I got pictures, the fit and finish, is leaps and bounds above the upper soft doors Honda made for the Pioneer, but think right where the talon drops water on to your front out side leg, from the roof. There is a pretty big gap thats is gonna let water still drip right from the roof, past the door onto your outside leg
Reactions: CumminsPusher
906UP
906UP
12,996
121,131
da Yoop
Is the Honda soft rear panel required for the door uppers?
Reactions: Skapegote
34,173
Well hell popeye, that’s bs......:confused:
No adjustments going to have any effect?
popeye
popeye
3,273
14,641
kapowsin, Wa
Looking at it further this morning, I believe it’s caused by my super atv windshield, because the place 2 clamps on both sides on the vertical A pillar, it causes part of the upper door frame to be tweaked just slightly and the foam door panel doesn’t relax like it should. Gonna run the hose over it once it warms up a bit to see how bad it really is. Might just be me looking to closely at it. Still leaps and bounds above the soft doors for the pioneer
Bigblue1
77
92
NC
I have the Honda hard rear panel, it's setup for both. It has velcro to hook with the soft rear.
34,173
I used the Seizmic soft doors on my Pioneer which were BA, they let no rain in.
34,173
Just an FYI, Seizmik tells me they aren’t making upper doors for the Talon’s and have no plans to......:confused:
13,342
64,863
I would bet it might have something to do with a non-compete from Honda.
I believe they are the OEM for the Honda branded stuff.
Reactions: NTCPrezJB
34,173
But they make uppers for the Pioneers.....:confused:
34,173
I just asked Seizmik why they have no plans to make uppers for the Talon.
34,173
They look and fit really good, if I were to buy a Talon I think they would be my choice.
Btw, what windshield does your friend have on his Talon?
34,173
I have the enclosures and they are great. The quality is good. The best thing about them is the latch. You do need longer bolts for the rear C clamps . You will not find anything better and I would not like adding snaps and using zippers to get in and out.View attachment 163041 View attachment 163042
Where did you buy the upper doors at, and do you know if they’re making them for the four seater. Also, what windshield did you go with and how does the doors fit along with it? Thanks
CincyCuda68
59
37
How hard are they to remove for the summer? Will you have to take the door shells apart each time you want to install/remove them?
Our shop friend has them installed and it appears you can zip the window out entirely and leave the frame on for warmer weather.
Reactions: CincyCuda68
jasond
jasond
220
350
Indiana
Correct. I’ve got them and you can zip the entire clear vinyl part out.
However, removing both of the entire doors is probably only a 30 minute process once you’ve installed them and understand how they install/uninstall.
Jefferson87
Jefferson87
258
275
Northern California
My 4 seat is at the dealer getting its initial service and the honda upper doors installed. I'll update this with some pics as soon as I get eyes on it.
Reactions: Montecresto
DavidHenn
5
We had the upper doors but were not that impressed with them. I had to build some troughs to keep the rain from running in on the top of the doors. For the price the fit is awful. Then on a ride on a 31°day the driver side window just started to disintegrate. They were never cleaned with anything but soap and water either. They have been sent in for warranty. Have not heard back yet. The clear part of the windows cannot be purchased separately either. The dealer said if the warranty claim goes through they will refund us our money for them. I was not impressed with them at all.
D507FFEE 5E5C 4368 8C2A A6C01424095F
