Talon Warn Bumper and Axon Winch Install
Ddoggy
Ddoggy
25
26
Alaska
Talon comes with the Factory Harness for a winch install...but with Warn Axon being an all enclosed unit, and Warn Bumper setting the Winch so far forward...how did those who’ve installed utilize the Factory Pre Run wires. Be a great length if you were mounting an external solenoid....not very friendly without a splice as far as I can see...aint torn into it yet...just looking for heads up and what worked best for those who’ve done rides before..Thanks in advance
Reactions: Isaiah
LilGreenMachine
LilGreenMachine
Auburn, WA
If it were me I would mount a fuse block with positive and negative terminals mounted in place of the solenoid. Then jumper from the pos/neg battery terminals to your winch. Now you have the added benefit of a fuse block installed for any future wiring you may do. I needed a solenoid so my fuse block is on the passenger firewall. I'll try and scrounge up a picture...
If you don't want a fuse block, just get a pos and neg bussbar and mount in the solenoid area so you just need a short run to the winch. There's really no room in the battery box for a bunch of cables, and why run cables to the back when they did it for you.
LilGreenMachine
LilGreenMachine
Auburn, WA
Here's a shot of my setup. Move the fuseblock over to where I have my solenoid. The little buss bar to the left of my solenoid is hot from ACC connector to run ACC power to my rocker lights individually.
Talon Wiring
CMB
CMB
5,108
55,091
  2. Talon X LV
I have the 45RC axon on my Talon. The winch kit comes with red and black cables to connect the winch. The Talon is already pre-wired. Pretty much plug and play wiring.
Reactions: Ddoggy
Ddoggy
Ddoggy
25
26
Alaska
👊great input and Thank you very much, and for the Pics of your set up. I’m new to SxS in ...well...all aspects lol...but I ain’t scared...but...old 🤣😂🤣...and always worry if I am going to remember where all those damn plugs went for each panel I take off 🤣😂🤣
Thanks to the team that puts this Site together..pretty cool to get honest input from all those who’ve replied. Installed the Bumper, the Winch, loomed the wires and brought them up thro the hood area, found the +/- Factory wires...and froze 😂🤣😂🤣
Thanks again for the ideas and Pictures 👍👍👍
Reactions: LilGreenMachine
LilGreenMachine
LilGreenMachine
Auburn, WA
No problem Ddoggy. Just remember, after connecting to the pre ran cables under the hood, you will also have to hook up the positive at the battery. It's tucked up behind the battery box a little bit but not hard to get to.
Reactions: Ddoggy
Mikehallad
Mikehallad
29
24
Highland, Utah
Which mount did you use with your Axion?
CMB
CMB
5,108
55,091
  2. Talon X LV
WARN 102600 ATV Winch Mounting Kit for Honda Talon 1000 SXS
Doogle
Doogle
186
249
Surprise,Az Cincinnati,OH
Where can I find the factory preinstalled wires that terminate up front on the Talon R? Someone said they were in the dash area, but I can't find them.
906UP
906UP
13,014
121,328
da Yoop
It's just the battery cables that are pre-installed. They will be in the upper left corner under the cowl.....between the hood & the dash, should have blue tape on the ends. The positive will also need to be connected inside the battery box to the positive side of the starter relay.
Doogle
Doogle
186
249
Is the negative already connected at the battery?
And where is the best place to mount the solenoid?
906UP
906UP
13,014
121,328
da Yoop
I think the neg is already connected to the frame or battery, I don't remember needing to connect it. There are mounting tabs for the winch contactor pre-installed on the dash bar/tube under the cowl in the same area, just to the left of the steering column (as viewed from the drivers seat). Once you pull the cowl off you'll see what I'm talking about.
Reactions: CMB and Doogle
Doogle
Doogle
186
249
906UP I really appreciate the quick and helpful responses. I'll try wiring up tomorrow. Today was mount winch, install rear windshield, and spare tire carrier. Some other members mention the need to attach the + at the battery. None say anything about the negative.
Thanks so much.
Reactions: 906UP
906UP
906UP
13,014
121,328
da Yoop
Thanks so much.
A quick check with a DVOM set on Ohms/resistance between the negative cable and and the frame will tell you for sure but I don't remember needing to connect it. It's been a couple years....LOL
