P700 Temperature gauge
Thedirkster
Thedirkster
15
16
Ceres, Pa
Has anyone installed a real temperature gauge into a 700 as opposed to the idiot lights on the dash??? If so where is the sensor tie in and where did you find a comparable gauge?
The temperature sensor is on the rear of the cylinder under the throttle body, i suppose you could find a T fitting and install a part store Autometer gauge in the fitting. This would keep the factory sensor and allow a "true" temperature reading.
41,813
Huh? Do the newer ones not have a temp gauge?
Thedirkster
Thedirkster
15
16
Ceres, Pa
Thanx for all the productive "comments". I guess what I didn't say is I'm not pleased with having to step through the push button status feature on the dash. I find that cumbersome and distractive while driving. It could have been designed better to be a more full featured display in showing numerous status's simultaneously. Which is why I sought valid opinion (minus the mockery) for adding a gauge.
I can't spend all my time riding so I like adding \ modifying the machine.
tjoreo
tjoreo
1,011
1,929
Southern Idaho
One thing I like on 1000 vs my old 700 is that the display stays on the gauge that you were watching after you turn it off and back on. I never ran out of gas on the 700 because it always came on at start up but like you hated going through to find temp each time. I was hoping this would be something they might fix on the newer units (mine was a '15) but an aftermarket gauge would be the way to go. Keep us posted how if you get it done. Thanks
41,813
You're welcome!
Similar threads
