P1000 The INFAMOUS Superatv Windshield / Honda Roof Gap! Fixes here
ehart814
ehart814
1,653
3,631
NWPA
I know it's been discussed many times, but I was searching and couldn't find the posts about the pipe insulation and whatnot, so I figured I'd make this post for everyone to show what they did to fill the gap and still have the ability to flip the windshield.
Pics are great! Amazon links for the needed supplies are great! Please, if you have the time, post up and be as detailed as possible. TIA
Honestly, if someone came out with a quality kit to fix the gap, I'd buy it.
Russ989
Russ989
22,642
147,257
I just live with it, not really bad enough for me to spend any time on it at this point.
Reactions: Isaiah and TimG
ehart814
ehart814
1,653
3,631
NWPA
It's bad if you ever get caught in the rain and everyone in the machine is soaked, front AND rear seat passengers. That's kinda why I bought a windshield and roof...to not get soaked
And lots of people enclose their machines in the winter. The gap lets a lot of cold air in.
TripleB
TripleB
15,618
140,488
Caryville, Tennessee
I stuffed pipe insulation up there because of the rain. We never got soaked but I seen it was gonna be a problem if you were moving while it was raining. The water would ride the roof top over the seats and start dripping. I dont have the doors so I just bundle up during the winter.
TimG
TimG
OLD SKOOL
795
4,006
Southern Indiana
I remember a guy using canvas tarp material and velcro, seemed like a pretty good solution with a little work.
Reactions: ehart814
ehart814
ehart814
1,653
3,631
NWPA
I don't have doors either.... I've heard about the pipe insulation but hadn't tried it yet. I am hoping this thread becomes a future resource for others because so many people buy the superatv windshield and the honda roof.
Does the pipe insulation stay put when you flip the windshield though?
Reactions: TripleB
TripleB
TripleB
15,618
140,488
Yes it stays put. I'm not sure what size it was. I got it from work. Its wedged in pretty tight. I will measure it when I get home.
Reactions: ehart814
Vikes79
Vikes79
SKOL!
11,773
114,148
South Dakota
  2. Talon X4 LV
I use this for above the mid panel bar to roof and on each side between the roll cage and roof.
For the mid panel bar I have to double them over long ways.
On the front Honda windshield I have long strips of pipe foam jammed in the gap.
It’s not 65 mph proof but it’s never came off on the highway.
I’ll snap a pic when I get home.
I’ve reused mine 2 seasons now and will easily get more.
I take everything off in the summer except the roof and run a rouge power screen.
Reactions: ehart814
Haldog77
Haldog77
NTC's Mafia Enforcer
39,918
346,659
Bossier City, Louisiana
I was worried my window would break from high wind while on the trailer. This is how I handled it. The foam came off of a fiberglass shower I installed at the deer camp.
B5C1843E 2542 44B7 BF10 0C75E191D6E9 845DB96E A10E 4881 9111 F0974DB03676 ABF1294A CD52 4383 AFC1 C6FAAD194694 146068CA 9D43 417E 8399 8E168DB6CC17 DCECA063 08BE 4EE6 AE08 5AD0B77A313E
Vikes79
Vikes79
SKOL!
11,773
114,148
South Dakota
  2. Talon X4 LV
Sorry that they are a bit hard to see.
A2E97D9C 7747 455D A975 9E7137D7D867
492128FC BD83 4847 8D9D EE9D00D361F4
01094E31 B740 4DCD BEF9 AF034A15D4DA
208,728
AZRocks
AZRocks
111
217
Phoenix
I sealed mine with clear flexible vinyl material from Hobby Lobby. It's similar to the material used in a tent-trailer window, or my CEC P1K enclosure windows. I used 3M dual lock adhesive strips on the top of the SuperATV split windshield, and the bottom of the Honda OEM roof. I did some measurements and made a template to cut the plastic material, then put dual lock on it to attach to the windshield and roof. Used 3M 4298 adhesion promoter before attaching the dual lock. It helped, though I'm not sure if it was required. I already had the adhesion promoter sitting around from the door seals project.
It keeps the wet out. I can open and close the split windshield without issue. I've towed it at 75 MPH with no issue. If I had to do it again I would use a slightly thinner and more flexible material. I doesn't need to be clear. Just something the dual lock tape will stick to well enough.
My template:
IMG 6741HP1K WIndshield Gap Barrier 1HP1K WIndshield Gap Barrier 2
208,728
My template:
I really don't like my Super ATV full windshield for all the above reasons, only time it's worth a poop is rain! With the upper open in nice weather the lower docent deflect wind like my Dolphin shortie does, I can wear a hat loosely and it stays put! Super ATV has some short coming and this is one of them as well as Dolphin! Make a shortie with the lip for deflection and the upper to match/fit! DUGH!!!!!! On both companies!!!!!
Reactions: TripleB
TripleB
TripleB
15,618
140,488
I told you I will give u a $100 for that piece of s***.
AZRocks
AZRocks
111
217
Phoenix
SupaATV three position flip-up, bay bay! Does everything I need. I've also had on since last fall a CEC enclosure with zip out fronts, and roll-up back windows. It will probably stay on the wagon until it falls apart. Only issue I have is it can get warm for the back seaters at low speeds, but full open kimono is the only cure for that.
Reactions: TripleB
208,728
I wouldn't be able to keep a full enclosure intact for very long, ride mostly tight woods, lots of brush. wish some one made a quick change with storage gizmo!
