Talon Things to check
Diegokid
62
89
nowheresville
Will be doing the 100 mile service on the Talon this weekend. Besides things listed in the owners manual can anyone else list things they have found during inspections not listed in the manual? I have already found some nit picky stuff.
Will also be installing the harnesses this service.
Diegokid
62
89
nowheresville
1. Steering wheel at 11:00 driving straight.
2. Driver side door panel aft end rubbing when opening door.
3. Rattles in both doors when riding, this isn't the rubber door stop. fixed the top rattle already, it was really bad.
4. When shifting into low range takes what seems like too much force.
Just things that annoy me.
HondaTech
Sorry your having those issues, in particular the steering wheel as that should've been corrected by the dealer.
As far as the door rubbing, if you take off the black plastic piece (3 mud clips) in front of the rear vent you'll see 2 bolts. Those two bolts can be loosened to move the door and get clearance between the fender and door panel. This may also fixed your door rattle as well.
The shifting thing seems to be a common issue, most likely needs the cable adjusted, which is listed as needing inspection during the first service.
Diegokid
62
89
nowheresville
Thank you for the door information. I tend to overthink things, has to do with previous job. Doing this will keep the wife and I busy for awhile. Before digging in to far does the front differential have any clutches or is the I-4WD controlled by brake application on an open differential?
HondaTech
There is a clutch connecting the driveshaft to the pinion, but there isn't a clutch pack in the diff.
Reactions: BWAF
BWAF
BWAF
I get paid to pass gas
8,869
42,495
Carthage MO
So could that be bypassed electronically to make push button 4x4
Reactions: PaulF
BWAF
BWAF
8,869
42,495
Carthage MO
PS trying to see if there is a way to do push button difflock
HondaTech
Not without changing the front diff and deleting the i4wd. When your in 2wd, the driver shaft coming out of the front of the sub trans is turning but isn't turning the front wheels, due to that clutch. When you press the i4wd switch it allows power to transfer the front diff from that shaft.
Your still not getting the front diff locked due to the stuff inside the front diff.
Reactions: BWAF
Diegokid
62
89
nowheresville
Strike number two. Before changing the front diff lube I noticed it's been leaking on the drivers side. Cleaned it up, changed it to monitor the leak since we are planning a ride this weekend I reckon I'll take it back to the dealer next week to get this fixed, slightly over 100 miles.
This is ridiculous.
Reactions: TripleB
HondaTech
This is ridiculous.
We've seen couple of diff seals leaking as well, seems to be their getting nicked when the axles get installed or maybe its run off from when the seal is installed. Honda has not asked any questions about replacing them.
Reactions: BWAF
BWAF
BWAF
8,869
42,495
Carthage MO
That's what I was afraid of
Diegokid
62
89
nowheresville
After cleaning, changing fluid and going for a ride I can say it’s definitely a leak. Going to monitor it and see if anything else comes up before taking it back.
stellarpod
stellarpod
821
3,025
OKC, OK - USA
Concerning Item 3: What did you find/do to mitigate rattles in your doors?
Steve
Diegokid
62
89
nowheresville
One of them was the driver door being slightly out of adjustment. Rest of the noises were some of the metal clips bolted to the door for the nets. I used O rings to quieten them down. Other thing was the adjustable straps on back of the nets will work loose and rattle. I just used some black nylon thread with my sail needles to stitch the loose end after tightening them up so it won't happen again. To remove you just use a stitch remover.
Worst rattle was the aft side of the roof both sides. There was just enough slack there to rattle at about 2500 to 4000 RPM. I just used a strip of rubber between it and the roll bar.
Minor stuff, just annoying.
hondabob
1,309
5,215
Prescott Valley, AZ
Always check the sub trans oil after changing the engine oil. There could be a newbie at the shop and it has happened on the Pioneer 1000 where they drained the sub trans by mistake.
Reactions: Ragnar406
Diegokid
62
89
nowheresville
Done that! After finding the front differential leak with just over 100 miles on it I checked everything.
Diegokid
62
89
nowheresville
We dropped the Talon off at the dealer on 14 Dec so we could have it repaired before our two week Christmas vacation with the grandkids. Still in the shop, called today they are saying the seal is now on backorder until 4 Jan 2020. My talon will have spent more time in the shop than at my house.
Diegokid
62
89
nowheresville
We picked up the talon yesterday, they said a tie rod end had to be replaced too, damaged threads when removing it, two days shy of 4 weeks. Funny that I have 1.5 months of warranty gone wit it being in a shop. Skid plate had a lot of oil in it so I’m assuming it’s from disassembly.
Weather permitting I will take it out this weekend to see if leak is fixed.
perry
perry
191
168
South Dakota
Mine leak from day one front dif. seal. I have a friend that has had it to the shop 3 time and they change the seal and still leaks!
